Old 10-01-2008, 11:42 PM
78 GHOST 78 GHOST is offline
Default VOE with R.A.R.E. oversized HO manifolds?
I'm planning exhaust solutions for my project 1970 GTO.
I was thinking about getting the Waldron VOE, but I think the mufflers are 2 1/4" which doesn't jive with my 2 1/2" oversized R.A.R.E. HO manifolds.
How can you make this combo work?
Has anyone run into this issue?
Thanks, Matt
____________________________________
"I work in high speed aluminum tubing."
Old 10-02-2008, 01:45 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Call Waldron Exhaust and talk to Joe Tontiello. He's the "Pontiac VOE guy" there. I met him at this year's GTOAA convention, where he displayed and demonstrated his GTO with the reproduction VOE system. I'm sure he'll have some suggestions for you. If needed, I could e-mail you a phone# for Joe.
Old 10-02-2008, 07:42 AM
Larry Navarro's Avatar
Matt, use the flowmaster reducer tubes at the mufflers. I had them on my 3" x 2.5" system.
http://store.summitracing.com/partde...part=flo-r2424
Old 10-02-2008, 04:38 PM
Tom Hand's Avatar
Tom Hand Tom Hand is offline
Exhaust Guru
Matt,
As Jack said, have Joe make them for you with 2.5" in and 2.25" out. He can do it. It will work fine with 2.5" manifolds. Or if you want the stock size for later usage, Larry's idea is good.
Tom
Tom Hand
Old 10-02-2008, 10:17 PM
Jack, Larry, and Tom:
Thank you all for your suggestions. It sounds like I should talk to Joe.
Tom, thanks for all your hard work on this project. I think this is a really cool idea and if money permits, I'd like a set on my car.
In your opinion, can the VOE mufflers be made with 2.5" In and Out?
If that is not possible, do you feel that 2.25" Out hurts performance any?
It seems like I remember this not being a huge issue on performance.
Old 10-03-2008, 08:16 AM
IMO, if money is an issue, you can't beat the reducer solution to solve your problem.
Old 10-03-2008, 11:11 AM
Larry, money is always an issue. However, I spent a pretty penny on the ceramic coated R.A.R.E. oversized manifolds, and the VOE setup is just under $1,000.. saving a little on a system like this seems a penny wise and a pound foolish.
I'll be surprised if I don't have close to $2K in the exhaust alone by the time it's done.
I'd really like to keep the 2.5" setup, at least to the mufflers. It seems like I read somewhere (Maybe Jim's book) that reducing after the mufflers doesn't really hurt much at all.
Old 10-03-2008, 11:30 AM
I probably should have put more detail in my response.
Keep the 2.5" system; nothing wrong with that at all.
Use the reducers just in front of the 2.25" mufflers and the 2.25" tailpipes on the outlets. Jim is correct on the smaller tailpipe senario and his testing pretty much proves that.
Spending $2K on the exhaust? Can't you buy just the VOE mufflers without the system.?
Old 10-03-2008, 06:01 PM
Tom Hand's Avatar
Exhaust Guru
Ask Joe to make them with 2.25" outlets and the true 2.5" inlet pipe. I think he can do that 78 Ghost. Should not be too much more, if any.
Tom
Tom Hand
Old 10-03-2008, 07:29 PM
Matt Meaney's Avatar
Matt Meaney Matt Meaney is offline
http://waldronexhaust.com/drivercontrolledexhaust.htm
they list the DCE muffler in 2 1/2" in and out. why not use that with your aftermarket exhaust? add a factory style control unit, best of both worlds.
Old 10-03-2008, 07:55 PM
carcollector's Avatar
carcollector carcollector is offline
I did what Larry stated and it worked fine.
Old 10-03-2008, 09:02 PM
http://waldronexhaust.com/downloads/...TION_CHART.pdf
ok, i've been looking for a while. no, not since my last post. very near the bottom of the page they list part # VOE-2A. this is a 2.50 inlet and outlet muffler for a 70-72 GTO.
Old 10-04-2008, 12:11 AM
1971/455/HO/4-SPD's Avatar
1971/455/HO/4-SPD 1971/455/HO/4-SPD is offline
Joe made me a system with 2 1/2 in and out to work with my 2.5" RARE manifolds. It can be done!!!!
Admiration for Ponchos..........
Old 10-04-2008, 12:34 AM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
very interested in this.i have a 72 lemans/gto that will have a +.030 455-ported 197 HO heads-comp XE288HR cam-2.5ram air manifolds.was thinking(i know dangerous)that the mufflers would be okay just cruising around and open them up when wanting more performance.just wondered how they would do with about 525hp and 575lbs torque?
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
Old 10-12-2008, 10:01 PM
Thanks everyone for all the replies. I think the solution I'll go with is to have the mufflers made in 2.5" IN and 2.25" OUT, so I don't feel like I'm losing anything upstream of the mufflers.
I know the money sounds like a lot, but the DCE system is about a grand, the R.A.R.E. manifolds coated were probably well north of $500, then the remainder of the system is going to eat up at least $500. That is going to be one expensive set of pipes.
The cool thing is the R.A.R.E. manifolds look great, and so far the ceramic isn't wearing off at all.
Old 10-13-2008, 05:15 PM
Tom Hand's Avatar
Exhaust Guru
71 Warbird, they will cost HP as compared to good straight through mufflers but compared to chambered mufflers, it will be basically a wash when they are open. But, you are already giving up some HP for the manifolds as compared to headers anyway so I would not get too overly concerned.
They will be really loud on that engine when opened and should be very quiet when closed..the big 455s really crackle when open.
Tom
Tom Hand
Old 10-13-2008, 06:26 PM
thank you Tom.i ended up with a pair of hooker supercomps pretty cheap,so i may run them for awhile,then go to the 2.5 ram air manifolds.
Joe
FREEDOM ISN'T FREE
Old 10-25-2008, 04:22 PM
jmt455's Avatar
jmt455 jmt455 is offline
Default VOE-2 mufflers
1971Warbird,
We have different internal tube diameters for higher-output applications. Send me an email or call me at the shop (800) 503-9428 to discuss the application. Since every system is built to order, we can pretty much make whatever you need. Inlets and outlets are available up to 3".
We've built several 2.5" systems for connection to 2.5" RA manifolds.
I'd recommend at least 2.5" inlets and tailpipes for your 455, with the "oversize" internal tubes. They will sound like turbo mufflers in quiet mode. Open = loud.
Joe Tonietto
Old 10-26-2008, 02:39 PM
Originally Posted by jmt455 View Post
1971Warbird,
Joe Tonietto
Thank you Joe.i will be in contact later for a system,seems like just the ticket.
Joe
FREEDOM ISN'T FREE
Old 10-27-2008, 04:11 AM
Oh, man, I sure mangled your name Joe! So much for my "memory like a steel trap"...
