Old 10-21-2008, 11:36 PM
abefromen's Avatar
abefromen abefromen is offline
Default chevelle 10 bolt
Will a '72 Chevelle rear end bolt into a '67 without issues? I know a different ujoint is needed but I think thats all.
Old 10-22-2008, 12:42 AM
It's a bolt-in.
Old 10-22-2008, 02:35 AM
Roadbuster's Avatar
Roadbuster Roadbuster is offline
It is wider flange-to-flange. 1 to 2 inches depending on which web site you believe.
1968 GTO with SC&C Suspension
Old 10-22-2008, 09:00 AM
Kenth's Avatar
Kenth Kenth is offline
You will find the same width drum to drum measuring a 67 GTO and 72 Chevelle rearend.
Also a 1972 Chevy 8.2" 10-bolt is the weakest axle from that era.
C-clips and wheel bearings running direct on axle shaft.....poor design.
Old 10-22-2008, 10:08 AM
abefromen's Avatar
Thats what I thought too concerning the width. I believe 64-66 diffs were an inch shorter flange to flange. 67-72 the same.
I found 3.36 10 bolt posi from a '72 Elcamino on CL. Seller wants $300 but supposedly it's plug and play. Seeing I don't have the coin for a new gear set and a posi unit and the cost to have it set up I was going to pick this 3.36 up.
Old 10-24-2008, 10:40 PM
scott cedergren scott cedergren is offline
That sound like a good deal I would jump. It will bolt in no problems, just the U-joint.
