Old 11-03-2008, 05:04 PM
Oak's Avatar
Oak Oak is offline
Default Dynagear Oil Pump??
Hi all.
Does anyone have some experience with this oil pump?
I did a search on the web for some info but didnīt find anything.
It has a 3/4" pick up hole and the bottomplate is 7/32" thick.
There was also one extra spring included in the box.
So , does anyone know if itīs a good or bad pump ,and what pressure it delivers.
Johan
1972 GTO ,455 HO ,WW5
1968 Firebird 350
Old 11-04-2008, 10:21 AM
PONTIAC DUDE's Avatar
Post
Dyna gear is out of business. Bought out by Melling. Was a better pump back when Melling was having internal trash and rust issues. Switcxhed over to them and then bought out. LOL.
Old 11-04-2008, 03:04 PM
Mr. P-Body Mr. P-Body is offline
I was thinking I had heard that (Melling "buy out"). I remember their (DG) sales "pitch" was they tested every pump with air, to be sure it was "right". We found several (Chevy, too, not just Pontiac) with pieces of Teflon tape in them, presumably from the air lines... Take it apart and clean it. It will be fine.
Jim
Old 11-04-2008, 05:10 PM
Oak's Avatar
Oak Oak is offline
Well that explains why I couldn´t find any info. Thanks!
Is there anyway to tell how much pressure it delivers?
I was aiming for around 60lbs.
Gonna take it apart and blueprint it.
Btw, do you know where I can buy some good headgaskets for a 350? 3.905 bore
Regards
Johan
1968 Firebird 350
Old 11-04-2008, 11:06 PM
wilcar wilcar is offline
Melling may have purchased Dynagear, but some of their stuff was purchased by SA Gear out of Bedford Park, Il. a Chicago suburb. They make timing sets for a lot of engine makes, both old and new. I recently bought a timing set off ebay that came from Jegs but had an SA Gear part number on it. Checkers sells their timing sets under the Dyno-Timing name I think. Dynagear owned factories in Mexico, Germany, and Taiwan. I think they still make some of their own gears and I know they get some of their chains from Japan. Maybe melling bought some of their companies. Their website is sagearinc.com but I could not get any info as it did nothing when you clicked on it. Cloyes is also Chicago based.
Greg Williams, Wabasha, Mn. 65 GTO, 455, DCI ported 6x heads, Isky Rpm 300 cam, 2-4's, 4 speed, 3.31
Old 01-13-2009, 04:50 PM
Oak's Avatar
Oak Oak is offline
Jim
Iīm about to deburr and blueprint the pump, so I took it apart today and look what I found...
Small pieces of cr.p , feels like some sort of hard plastic. There was loads of them..
Wonder what they could have done if they had got into the engine
/ Johan
1968 Firebird 350
