Old 11-15-2008, 09:14 PM
Axle07's Avatar
Axle07 Axle07 is offline
Default Well I need a new carb...
My Q-Jet rochester has given out on me. I finally got my T/A running today and the other set of barrels on the carb aren't kicking in. So anyone have an opinion on what kinda of carb to buy for a 77 T/A? Or pass a free carb my way lol.
Thanks.
Old 11-15-2008, 10:47 PM
67drake's Avatar
67drake 67drake is offline
I'd rebuild the Q-jet.
‘55 Catalina
Old 11-15-2008, 10:55 PM
carbking's Avatar
carbking carbking is offline
May be something very simple to fix. If you are trying to get the secondaries to kick in when the vehicle is in the garage, probably not going to happen. If the secondaries don't kick in on the road test, try to determine why not. Is the choke plate opening completely (vertical position)? Are the secondary plates stuck closed from long disuse?
Jon.
Old 11-16-2008, 12:40 AM
Axle07's Avatar
rebuilt it already. i'm pretty sure its just worn out and i tried to get them to kick in on the road with no success.
Old 11-16-2008, 12:58 AM
abefromen's Avatar
abefromen abefromen is offline
q-jet secondaries don't "wear out"..............something is keeping them from functioning.
Old 11-16-2008, 01:26 AM
Ford5of5's Avatar
Ford5of5 Ford5of5 is offline
Axle Ive had a similar issue with a crappy Ebay rebuild. You should take a good long look at how the choke and secondary linkages operate on the passengerside of the carb. I'm a backyard mechanic so I can't give you a name for the doohicky that I had to bend into proper position or the spring that the crappy rebuilders put in wrong. It might hhelp if you have access to a similar qjet to see whats suppose to happening. Dont buy any rebuilt carbs from ebay unless you know for a fact that its a repretable builder. Theres a lot of hacks on ebay selling crap remans. But back to qjet vs tripower, I'd only use the tri power for wow factor because they do look freakin' awesome!
Ya I like kittens, but I also like guns. Thank you Vets!
Old 11-16-2008, 09:50 AM
67drake's Avatar
Might want to post some clear pics if you can't figure it out. I've seen some members here "fix" carbs,just from pics posted.
‘55 Catalina
Old 11-16-2008, 12:19 PM
Kenth's Avatar
Kenth Kenth is offline
Believe it or not, even the best carb ever made needs some maintainace after 20+ years of service.
You just happens to have one of the best carbs ever made.
Give it a good clean out, jiffy kit, new float and at least a new primary choke pull off, (sec choke pull-off is an option in my opinion).
Why not start with ordering Cliff Ruggles book on Q-jets, then you´ll be good to go.
Old 11-16-2008, 12:53 PM
Axle07's Avatar
I've put a kit in it and replaced the float the last week in October. I'll try to get some pictures up or something.
Old 11-16-2008, 12:57 PM
Chiefpontiac's Avatar
Chiefpontiac Chiefpontiac is offline
Is the choke operational or have you disabled it? There's a link under the choke housing that locks out the secondaries until the choke has dropped off completely. If it's not opening completely, the link might be staying engaged...
It's the secondary lockout lever in this picture.
Name:	QJet choke 001.jpg
Aut viam inveniam aut faciam
1971 Trans Am 455HO M22; Cameo White / Blue
1971 GTO Convertible 455 M40; Starlight Black / Black
Old 11-16-2008, 05:28 PM
andyg's Avatar
andyg andyg is offline
Send a message via AIM to andyg
I had a similar experience with the secondaries not working on my qjet. I rebuilt it myself but I had not prior knowledge of them. I don't know what was wrong with mine but it worked fine after I took it back apart and put it back together. That was a simple enough fix for me you might want to try it.
1969 GTO. Full rotisserie restoration "completed" in 2014. 5.3L "LM7", TKO600, 3.55's out back. Big cam coming soon.
Old 11-16-2008, 05:32 PM
grandville455's Avatar
grandville455 grandville455 is offline
Post Pics!..It will help us and u alot!.. I love My q-jet!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 11-16-2008, 08:37 PM
77birdman's Avatar
77birdman 77birdman is offline
Thanks.
I have one 17058394 in working condition. I also have another from around 1974, the guy I got the engine from said it was an 800cfm, it is in rough shape. If you were closer I would sell you the working one for $50 and just give you the other, unfortunately shipping is expensive these days.
Can do the talk, can't do the walk......therefore need deep pockets
Injection is nice but I rather be blown
If you got it flaunt it, if not fake it (Snoopy)
Original 1977 Firebird / Welded tube frame connectors
TH350 with shift kit / 400 bored/stroked to 455 by PDude
OCD=Waxing and polishing your oil filter
SICK=wetsanding your exhaust pipe
