Old 11-24-2008, 03:35 PM
Oak's Avatar
Oak Oak is offline
Default 700R4 Rebuild Kit
Hi.
I´m going to rebuild my 700R4 (1988) tranny and was wondering which of these two rebuild kits I should buy.
Is there any other parts that I need to change for it to handle the torque,
for example: Different Servo , Clutch Springs etc
*TCI Pro Super Transmission Overhaul Kit:
http://store.summitracing.com/partde...5&autoview=sku
*TCI Maximizer Rebuild Kit:
The tranny is going into my 68 Firebird with a Pontiac 350 engine.
Horsepower level around 300-320.
95% of the time on the street, no-nitrous.
Johan
1972 GTO ,455 HO ,WW5
1968 Firebird 350
Old 11-25-2008, 06:18 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Neither one of those kits has "everything" you will need for a complete/correct rebuild. I would also replace the bushings, thrust washers, and install a molded 3-4 apply piston. You may also consider the larger "Corvette" servo. The 1988 unit has upgraded internals, including the larger low roller sprag and overdrive sprag. You may want to get one of our new books on rebuilding/modifying them, as we cover upgrades and rebuilding, as well as torque converter selection and retrofitting......Cliff
Old 11-25-2008, 02:20 PM
Oak's Avatar
Oak Oak is offline
Ok, great.
I have just ordered the book.
Looking forward to read it and learn the right things to do with the tranny. Thank you.
/Johan
1968 Firebird 350
Old 11-26-2008, 04:32 AM
ProBuiltAutomatics ProBuiltAutomatics is offline
If you are interested in very complete kits, go to https://www.700r4l60e.com/store/home.php?cat=19 There are several to choose from. I have been offering these kits for several years, and I am constantly improving on them. Dana
Old 11-26-2008, 03:35 PM
Oak's Avatar
Oak Oak is offline
Really good tip, I will contact you when it´s time to order the parts.
/Johan
1968 Firebird 350
Old 11-26-2008, 06:22 PM
DPlum DPlum is offline
A 700 that old will need alot of updates just for stock use you may find a newer one.
