Old 12-02-2008, 09:15 PM
1stgenbird's Avatar
1stgenbird 1stgenbird is offline
Default 67 Firebird Carb Parts Wanted
I am in need throttle body and float bowl from a 7027273 Q-Jet carb. My car has a Holley on it now but I have the original carb but the fuel inlet is stripped and the throttle body has a broken shaft.
Old 08-22-2009, 02:01 PM
6d7gto 6d7gto is offline
While researching 7027273 I ran across this posting. Those problems with your original carb can be repaired.
Old 08-22-2009, 06:30 PM
1stgenbird's Avatar
I took the card to a local shop that has been rebuilding carbs for 20+ years and he wasn't too optimistic. However, he did not have any parts available to fix the affected areas either.
Can you recommend a good rebuilder?
Old 08-22-2009, 08:07 PM
D. Rustin D. Rustin is offline
I have some spare quad parts let me look tomorrow & I'll post what I find tomorrow night.
Old 08-22-2009, 11:45 PM
Try and post a picture of the bad inlet and maybe one of our members can give advice. I have a '67 carb where the inlet is very thin and my carb guy says he can still salvage it. The broken throttle shaft is a minor problem unless it's rusted into the base plate. Even then I know a guy who can remove it. Is your carb a Rochester or Carter?
Robert
[email protected]
Old 08-23-2009, 07:05 PM
Both of the carbs I have side inlet's.
Old 08-23-2009, 08:40 PM
Cammer-6 Cammer-6 is offline
unless its been in the ocean for a few years that carb is worth saving.
contact Cliff R. or Jon Hargrove on this forum
Old 08-24-2009, 09:39 PM
Formulabruce's Avatar
Think I have a core laying around. Ill get someone here to dig through them soon.
" Long may we DRIVE !"
