does anyone know who makes a direct bolt in kit to take the power brakes out and put a manual brake step in?i was on some g body site and one guy did one in his malibu,you had to do this , you had to cut that, you had to fabricate this....,i want a kit as easy as possible that works,i dont want to find out at 135 mph that it doesnt!
try this trz motorsports makes a nice kit too that is similer to below.
http://www.dragracebrakes.com/galler...p?g2_itemId=19 trz motorsports makes a nice kit too that is similer to above. I like the trz kit better cause the strange master cylinder's pushrod stays in the cylinder and cant fall out
i love racing at the track |
I have the kit shown on my Cutlass (Pontiac Powered).
The rest of the brakes system is rebuilt stock with the exception of braided front lines and aluminum rear drums. My "front" line goes threw the line lock then to a splitter mounted on the center of the cradle. This way the front line are the same length. That may not matter but makes me feel better, being "type A" . The rear brakes are direct also ( no proportioning valve) but they go threw a 10# residual valve. ![]() The pedal is firm and stops well, but I have "only" tested it to 131 mph.
"resurfacing Pa highways 2 long black strips at a time" 78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z Best to date [email protected] mph at 3250# 79 Grand Prix, will be new home for the 440 Goal 9.75z@135mph at 2900# 83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z Making it the Ultimate Utility Vehicle Go, tow and show (not so much show, yet) Last edited by shotgun; 12-18-2008 at 10:48 AM. |
well that looks like the kit for me,that,ll give me something to do this winter and shotgun since you tested it at 131 im sure it will hold me at 135-136,hey 10secgp is that car coming to norwalk this year?
im thinkin of takin a trip to norwalk this year with my poncho powered 79gp. gonna try to talk my other pontiac buddy here with me to take his car as well
as long as the price of gas stays down joe you should come on over,we have a pretty good time,big party with racing in between.i think there is a guy ober your way with a red grandam runs high 10s?you know the guy?
yep, gas is down, and plus i will be wanting to travel anyways this year with the car, since it will actually be done this year. but, i do not know the guy. poncho powered?
I was over on another forum asking about a inexpensive way to convert the power brakes on a "G-Body" to manual ones for drag racing.Here is the link that someone shared with me on how a few have been done.Don't know for sure personally of how well it holds up,builder claimed it has no issues,you be the judge on that, but sure beats the big money for the others I have seen.Click link to view another method.
jts http://www.maliburacing.com/manual_brake_conversion.htm Quote:
Have you ever thought about using the master cylinder/self contained system like the GN's use (I don't mean the earlier hydoboost system)? Thats what I run on my Regal race car and as it has its own air pump (doesn't need any vacuum source) so you can run any size camshaft/lift/duration and it will not effect the brakes but will stand the car on its nose if required. My Regal won't run 131 mph but it will run 127 mph and I can stall it to 3200 rpm or so before the torque of the motor over rides the brakes. If you were to go with this system you would also need the plate that this system bolts to as the 4 studs on the back side of the plate will match the 4 stud holes your current system uses to bolt to your firewall. Just another option.
i tried calling that dragracebrakes and emailed,no answer or call back and no email,
talked to trz,went with them thanks for the help guys,they have some other pretty good g-body stuff,looks like i,ll be getting more from them. a antiroll bar is next
hey! to the guys that have the trz brake kit,how far did you guys adjust the rod that they give you?high pedal , low?
well i put the kit in and took the car to the track on memorial day weekend,had to take the last return road every run,not too bad to stop,but if i go to a track other than pittsburgh raceway or norwalk,i might have a problem,what suggestions for stopping this alittle better ?and rotor upgrades?i was told by a old school guy to use smaller bore wheel cylinders for more pressure?
