Old 12-24-2008, 12:48 PM
Cheyenne's Avatar
Cheyenne Cheyenne is offline
Default Correct Flywheel
Putting a clutch set up on a 62 389. Have the bell # 9770091 ,,but not sure how to ID correct flywheel ,was told 61-2 are there own. 166 teeth but something about the center hole ??
I am the apocalypse,,dressed in a Bunny costume
Old 12-24-2008, 12:51 PM
tom s tom s is offline
call Brad at Fabfraft,he can give you the best info!Tom
Old 12-24-2008, 12:54 PM
also a 977 bell is not correct for a 61-62 car?Tom
Old 12-24-2008, 06:00 PM
Cheyenne's Avatar
call Brad at Fabcraft,he can give you the best info!Tom
thanks,but not looking for the $300 flywheels they sell ,,just asking about a stock one and how to ID it
And im told the bell will work ,,just the the top bolt holes were larger
Old 12-24-2008, 07:22 PM
ASK him for advice!He can tell you the diff.Also if your going to do ANY hipo stuff you will NOT want a stock cast flywheel if you value your feet.The bell will fit but you will need to mod if your going to use stock 61-62 clutch linkage.Tom
Old 12-24-2008, 08:40 PM
Cheyenne's Avatar
Thank you
