Old 01-19-2009, 09:07 PM
steve's Avatar
steve steve is offline
Default drip moulding removal
ok so i figured out that is what it is called. the chrome piece around the window. i pulled the rubbers seal out and removed the screws. it still wont come off.....its like it is glued in. i need to get this thing off before i take the car to be blasted.
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers....
Old 01-19-2009, 10:07 PM
GoatDr GoatDr is offline
That's not the drip rail moulding. It's the window seal moulding. The chrome piece is stuck in with black sealer(like 3M sealer). You'll have to use a putty knife to slowly pry it loose. The stainless is pretty thin, go slow. Sorry on an F body it might be a comb deal. On my A body it's separate.
GoatDr
Old 01-20-2009, 07:22 PM
x-bird2 x-bird2 is offline
two separate pieces, the vertical chrome and the horizontal drip rail. if you've gotten the seal out of the channel, and the channel piece off, make sure the chrome is cleaned off and not hiding any rivets or screws up in the corner before you attempt to pry it off. with the optional decor package, there are 3 pieces, the seal, the channel frame and the chrome. if you have access to a heat gun, use that, or use a hair dryer and get it nice and hot to soften up the sealer, if that's what's there.
Old 01-20-2009, 08:04 PM
steve's Avatar
thanks a lot man...i really need to get this stuff off. the car had a vinyl top and there are fragments stuck under the chrome piece. i should get a chance to get at it this weekend. the car has a two piece set-up. the horizontal piece came off easy and was two metal pieces. the other hunk seems to have a bunch of sealer holding it on. the heat gun is a perfect idea.
