Old 01-20-2009, 04:33 PM
triathlonx13's Avatar
Question Fiber Glass doors and Lexan Windows
I have a set of fiberglass F-Body doors. Does anyone have experience installing them? Who sells the lexan windows? I've seen some windows on cars that have a black edge around the window that I like. Also any information on how to get the windows to be able to be in the up and or down position would be great.
Any help and pictures would be appreciated.
Thanks.
Old 01-21-2009, 04:21 PM
bump
Old 01-21-2009, 04:45 PM
ventura7211's Avatar
ventura7211 ventura7211 is offline
Thanks.
Lexan widows;
http://www.eharwood.com/catalog/prod...?productID=114
or you may try
http://www.percyshp.com/Speedglasspage.htm
All the windows I've seen have came clear, the black border is painted on.
Old 01-21-2009, 07:28 PM
Ron Genovese's Avatar
Ron Genovese Ron Genovese is offline
My fiberglass doors are attached with factory hinges. You just use nuts on the inside of the door since the door doesn't have threads like the factory steel door. I think it gets more complicated when attaching fiberglass doors to a fiberglass body. You can easily make your own windows if you have a pattern from the original window glass. I cut mine out with a special jig saw blade meant for cutting lexan, then sanded any cut marks out with 120 grit sandpaper with a block. The black border is there to cover up the mounting bars that hold the lexan in place. The paint I used was made by Bickel and sold for that purpose. You need to sand out the area (until it turns solid white) that you want to paint, so that the paint adheres. I'll post some pics of mine tomorrow.
66 GTO
Old 01-21-2009, 07:34 PM
Hey Ron thanks a lot. Your information helps !!
Old 01-21-2009, 07:44 PM
Here's some pics.
Name:	lexan pics 004.jpg
ID:	155300   Click image for larger version
Name:	lexan pics 006.jpg
ID:	155301   Click image for larger version
Name:	lexan pics 005.jpg
66 GTO
