Old 03-17-2009, 07:48 PM
69 redbird's Avatar
69 redbird 69 redbird is offline
Default B&M shifter in a 69 FB
I'm wanting to buy a B&M shifter for my 69 FB with a 2004R trans in it. I the mega shifter which has to part#s 80692 and 80694 these are made to fit 1970 on up, but I have a 69? Has anyone installed one of these? Please help?
Old 03-17-2009, 08:13 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
The 80694 is a 'drop in' installation on 70-81 Firebird, T/A consoles. We installed one on my son's 69 Bird with a little creative engineering; had to remove the factory shifter bezel and use the one that comes with the B&M shifter. Easy enough to go back to stock if need be. Also, I think the B&M comes with an indicator plate and a feature for the extra detent to accommodate overdrive transmissions like the 200-4r.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.60 @ 126 so far...
Old 03-17-2009, 08:18 PM
amcmike's Avatar
amcmike amcmike is offline
Can you please post a pic?
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 03-17-2009, 08:24 PM
69 redbird's Avatar
Default Thanks
sounds good, I guess i will give that one a try... If you have a pic? i would love to see it.
Thanks,
Old 03-18-2009, 09:34 AM
Guys, not sure how to attach a pic to my post but I will give it a try. If that doesn't work you can pm me your e-mail address and I can send one that way. It may be an hour or so before I can get to it.
Old 03-18-2009, 10:55 AM
Okay, let's give this photo thing a test.
Old 03-18-2009, 11:11 AM
69 redbird's Avatar
Default Thanks
I ordered mine last night and they called me already and said it was in
Old 08-02-2009, 12:27 AM
69 redbird's Avatar
Default B&M shifter
How much did u cut out from console? If i screw my shifter down i can't go into my low gears? I try to see whats stopping it, but can't tell yet... If u have any pics of before you put it together i would like to see it.
Thanks,
Old 08-02-2009, 09:57 PM
It has been several years since the install and I don't remember all the details but I know we didn't have to cut the console. I am sorry I didn't take a few pictures while we were doing the work. If I can find the time I will try to get a pic with the bezel/boot assembly out of the way; might be of some help.
