Old 04-04-2009, 12:53 PM
cdb cdb is offline
Default 1975 OEM gauge cluster questions
I have a 1975 455 4 speed car I am restoring. The gauge cluster looks to be incorrect, the speedo is 160 mph, and the tach is 8000 rpm. Are either of these correct for a 1975 Trans am ? Everything else in the dash is original such as radio , 8 track player etc, so it has not been a torn apart car. What speedo and tach should be in this car , the 100 mph speedo, and the 6 K tach ? TIA, Craig
Old 04-04-2009, 04:56 PM
Held for Ransom's Avatar
What is the tach redline? What are the readings on the water temp gauge?
Old 04-04-2009, 05:07 PM
cdb cdb is offline
the redline starts at 5750 and goes all the way to 8000 (of course). The water temp is 100, 220, 260. The other thing I am wondering is , my 160 speedo has the two holes at bottom for the brake light, and the fasten seat belt light,as the 75 -79 100 MPH speedos are. All the 160 speedos I have seen only have a rectangular single hole for the brake light. Any idea what I have, did the factory make the 160 speedo with the two indicator light holes ? Craig
Old 04-04-2009, 05:51 PM
77 Canamman's Avatar
Lightbulb
The speedo in your car came in mid 1972-1974 Firebirds. The speedo with the single brake warning lamp came in 1970-early 1972 Firebirds.
1975 Firebirds would have come with a 100 MPH speedometer.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 04-04-2009, 07:53 PM
How early in the '75 model year was the car assembled? The 100 220 260 suggests a '74 package (maybe late '73).
Old 04-07-2009, 05:05 PM
sinister76ta's Avatar
sinister76ta sinister76ta is offline
Default 75 Speedo
The 75 speedo cluster came with the 8k tach and the same water/oil gauge markings as a 74. The only difference is the speedo in the 75 was 100mph and the 74 was 160mph. The speedos can be swapped out real easily in the clusters as the speed is only held in by 2 screws in the back and the plastic cover.
Old 04-07-2009, 07:27 PM
form74's Avatar
form74 form74 is offline
I have a 100 MPH speedo out of a 75 Formula if you need it, the rest of the of the cluster is in my 74 with my 160 speedo.
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Old 04-07-2009, 11:29 PM
I think I should have said the 100 220 260 started with the '74 (possibly late '73) model. But, I'm still not convinced that an early build '75 COULD NOT POSSIBLY have a 160 speedo installed from the factory. Just as you're stating that they had 8,000 RPM tachs.
Old 04-08-2009, 08:09 AM
BAD455TA's Avatar
BAD455TA BAD455TA is offline
I will swap you mine...I have a 100 Speedo and 6K tach...always hated it, want the 160/8K
