Old 04-07-2009, 06:12 PM
79bluebird's Avatar
79bluebird 79bluebird is offline
Default 4 speed
i wana put a 4 speed in a firebird and need to know where to put the hole for the shifter.
you call yourself HARDCORE but are you truely hardcore
Old 04-08-2009, 01:44 PM
Cammer-6 Cammer-6 is offline
search a little
I posted a picture with the ruler next to it.
someone else posted a drawing the the dimensions.
Old 04-08-2009, 07:07 PM
skidjvp's Avatar
skidjvp skidjvp is offline
this may help --jvp--
ID:	164774   Click image for larger version
Old 04-09-2009, 08:30 AM
frankyboy455 frankyboy455 is offline
Hey JVP, this diagram must be for 68 and 69, right ? I once converted a 67 from 4 speed to automatic and the hole was the very same, and I think this stands true for 67 Camaro as well, is my memory right ? If 79bluebird has a 67, maybe he does not have to modify anything. Frank.
Old 04-09-2009, 02:12 PM
Bum67 Bum67 is offline
If you presently have an automatic in the floor, then the hole is exactly the same as a manual transmission. Even the screw holes for the boot and trim are the same. No cutting is required. TMy car is a 67 Firebird.
