Old 04-15-2009, 08:13 AM
cressy cressy is offline
Default Rear disc brake gear ratio
I am looking at a 79 and 80 TA for parts and both have rear disc brakes.
I just want the posi unit to put in a non rear disc brake rear end.
Were the rear disc brake gear ratios the same or could you get any gear ratio?
The 79 had a 403 Olds, the 80 had a regular 301 engine.
Old 04-15-2009, 01:05 PM
2manyT/A'S's Avatar
I believe the standard 1979 WS6 rear ratio was 2:73 (which most had),but have documented several 79's with optional 3:23's
As I recall,3:08's were mandatory for all 80-81 WS6's
Old 04-16-2009, 08:04 AM
Thanks for the info.
Even the 2:73 ratio could be changed to 3:90 without a ring gear spacer then, correct?
Old 04-17-2009, 06:37 PM
formulapk formulapk is offline
i may be wrong here but it was my belief that the 2.41 and 2.73 were in a class of their own. . .requiring spacers to upgrade.
Old 04-18-2009, 11:33 AM
Correct, the 241/256 carrier requires a spacer to run lower gears. 273 down everything fits.
Old 04-18-2009, 12:00 PM
2manyT/A'S's Avatar
For cruising & a bit of spirited street driving,the spacer should be OK,but if you are planning ANY serious drag racing,you should just start with the correct series carrier. JMO
Old 04-18-2009, 04:12 PM
Thanks for all the replies.
