Old 04-16-2009, 12:13 PM
63 Pontiac's Avatar
63 Pontiac 63 Pontiac is offline
Default 400\455 into '62 Chevy dually
What would it take to drop in a Pontiac 455 into a '62 Chevy? This is a one ton dually with a 4 speed and granny low first gear. Besides motor mounts and driveshaft, etc, wondering about the bellhousing\transmission matching up.
1963 Catalina 2 door hardtop
1968 Catalina 2 door sedan
Old 07-07-2009, 09:44 AM
63 Pontiac's Avatar
Anybody got any ideas?
Old 07-18-2009, 11:11 AM
junkcollector junkcollector is offline
Chevy bellhousing won't bolt up. Have to use a BOP. Some of the wiring will be a bit different. Starter is on opposite side of chevy as is alternator is memory serves. Biggest things will be the mounts other than that should be cake. I put a '77 400 into a '71 c/20 piece of cake all in all.
Old 07-18-2009, 04:50 PM
I think, and it's been several years, that a dual pattern lakewood or similar blowproof bell will work for this.
I don't remember what mounts we used in the one I installed either. Mounts will be the easy part of this. Finding the correct bellhousing will be the issue
Mike
former." --Albert Einstein
- Winston Churchill
Old 07-18-2009, 07:51 PM
all you need is a pontiac bellhousing. and problem solved on that part.
Old 07-22-2009, 11:17 AM
63 Pontiac's Avatar
So a BOP bellhousing will bolt up to that tranny? That's good news, thanks.
Old 07-22-2009, 06:11 PM
I'd check it first, the one I did the pattern was different form the bell.
- Winston Churchill
Old 07-22-2009, 09:28 PM
63 Pontiac's Avatar
10-4, this is a back burner project for now as it just got a small block swap. Hopefully the small block will be stout enough but if not then I'd look into the Pontiac mill. I'm thinking about the future for not only this truck but also a GMC suburban that may show up in the driveway.
When the wife's not looking that is...
Old 08-23-2009, 08:26 PM
goquick's Avatar
goquick goquick is offline
The lakewood bellhousing will slove your issue as well as make a stronger support setup for the engine/trans combo. But I'd look at a mid plate set up because if I remember right there is no support between the engine mounts and tranny mount.
