Old 05-13-2009, 03:56 PM
oville oville is offline
Default Hot starting problems
Car is 71 bird with 400, once its hot starter barely turns it over. I have replaced both cables (stock autozones), battery (everstart 850cca) new mini-starter, 100 amp alternator & wrapped the headers near the starter, its a little better, but not much. I have electric fans & installed a kill switch to turn them off when I want to start, so I am not pulling current away from the starter. Don't think I should need 2 batteries? Any advice?
-Thanks
Old 05-13-2009, 04:22 PM
ericwy's Avatar
ericwy ericwy is offline
What's the CR and the timing set to? Even my 9.2:CR likes to kick back against the
starter after a brief hot soak. Most times I just let go of the key and hit it again.
If its really being an ornery about it, dialing back the timing (MSD timing control)
makes it spin easily.
1977 TA 400 9.5:1 CR 351hp 414LbFt, #13 Heads + 1.52 Roller rockers, 1968 Pontiac 400 intake, Holley 4165 650 DP #7054
Howards Hyd .447/.467 IN:288 EX:298 214/[email protected], MSD6A + MSD timing control + H2o/Meth
1-5/8" headers, Magnaflow 200CPI Cats + 2.5" Pypes X, Dynomax STs, TH-700R4 2200 stall, 3.42 Eaton 10-bolt, PS/PB/PW/PL/AC/Cruise
[email protected] 2.18 60' on P255-60-R15 radials, pump gas, mpg : 21.5 hwy 15.2 city
Old 05-13-2009, 04:28 PM
J_JAMNIK J_JAMNIK is offline
I bought an MSD 6 box that retards timing while cranking the engine. Used it on a 68 YE engine with great results. Starts very easy with lower compression heads.
Junk is something you've kept for years and throw away three weeks before you need it!
Old 05-13-2009, 04:52 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
This is a problem. Make your own from 2 or 0 gauge welding cable -> clears up any hot start issues I've ever had. The "4" gauge off the shelf replacement stuff doesn't work very well on our cars in my experience.
