Old 06-02-2009, 09:19 AM
4dr 4dr is offline
Default 1970 400 WT manual
Are there any issues with using an automatic tranny with this block.
Old 06-02-2009, 09:30 AM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
None whatsoever.
Old 06-02-2009, 10:20 AM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Exclamation
YES! You must trade me that block for an automatic block, or it will NEVER work!!!
-Matt
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 06-02-2009, 12:32 PM
4dr 4dr is offline
The engine code legend indicates auto or manual, so I thought maybe there was some hook-up issues.
Is $400 a good price.
Old 06-02-2009, 03:06 PM
GTOLou GTOLou is offline
If your looking for a good pre-75 400 block, then you prolly could find one for 1-200 cheaper. If you are looking specifically for a 70, WT block, then yeah, that is a decent deal.
Old 06-02-2009, 03:34 PM
steve's Avatar
steve steve is offline
i bought an intake to pan 68 400 for 300.00
Old 06-02-2009, 05:34 PM
I bought a 76 manual tranny trans am 400 motor (actually a pretty rare motor as 30,000+ TA's had autos and 5500 400engineTA's had a manual that year) two weeks ago for $100.00 intake to pan. Yes, it is the suspect 557, but was code/casting and date correct for my 76 400 4-speed TA...
Anyway, 400 for just the block is prolly a little high, unless the casting/code (WT), date, etc., mean something to you...
Old 06-02-2009, 05:38 PM
GTOLou, can you share the Motor Unit Number directly above the WT as well as the original vehicle's VIN? Was the flywheel still bolted to it?
Old 06-02-2009, 09:32 PM
Rocky - it is a WY motor. AND, it was from a 400, four speed formula. He pulled the flywheel before selling it to me. He's prolly still got it...?
I wasn't sure about getting it, but your research helped w/ the fact that WT AND WY motors were found in 4 speed 76 TA's.
If you still need the number, I can get it...maybe not since it is from a formula? Let me know..
Old 06-02-2009, 09:49 PM
Thanks Lou, I thought the post sounded familiar!
If it's a WY block, it would have had a small register flywheel with an 11-inch diameter clutch disc.
I'm still trying to determine the crossover point the change occurred so the MUN and VIN on your block might help narrow it down.
