Old 06-05-2009, 10:04 AM
Default Microsoft Office 07 Question - Word
Look at the pic below. This is how it appears when I simply open a new Word doc.
  • The page size is set to 7 1/2 X 9
  • The Top Margin is correct but the side margin is set to 0
  • The paragraph line is set to center justified
WTH? I have tried to set it to default and even change it for one single doc, but nothing changes. At this point Word is useless. I dont know how this happened. Any suggestions?
Old 06-05-2009, 10:12 AM
RR67GTO's Avatar
RR67GTO RR67GTO is offline
Yeah, I've used all the prior office programs for years. Back to windows 3.1. I bought this one and after two hours I uninstalled it, and went back to Office 2002. Besides, I no like the cartoonish look it has.. Call me old, but there is a reason sometimes I keep what works for me. Mike
Build it fast, build it right, hold On TIGHT !!!
Old 06-05-2009, 10:13 AM
OhMyGoat's Avatar
OhMyGoat OhMyGoat is offline
You are in the right ribbon tab. Have you tried clicking on Margins and then go to Custom Margins. Check the three tabs under the box called Page Setup. See if that helps.
Alan
Tomorrow is often the busiest day of the week.
Old 06-05-2009, 10:21 AM
george kujanski's Avatar
Yep, office 2007 sucks. For whatever reason, microsoft won't leave well enuf alone. They can't add "features" without changing the user interface.
Go to "page layout" in the menu bar and then "size" , obviously for size, and "margins".
I don't know if it'll default to those settings next time but there's prob some way to set the defaults.
I also tried 2007 but quickly removed it and went back to 2003. 2007 is on my work computer tho.
George
Old 06-05-2009, 02:17 PM
Ive been to the margins tab. Set it to default and even changed it to the Office 03 option it gives you. No luck.
Even if I change the margins for a new doc, it still does it. Nothing changes. I hate and I mean this in the true sense of the word, HATE Office 07. Its on my work laptop and I cant change it.
Funny, Publisher is a part of Office 2007 and its functionality is the same as previous Office versions.
Old 06-05-2009, 04:04 PM
John V. John V. is offline
I am no wiz at Word and I continue to use an even older version than most. Biggest gripe I have, folks have started to use the new versions of Word & Excel and send attachments of the .docx and .xlsx files which of course cannot be opened by those of us that use the older version. I'm told they can save in the older version, but it is a pain when they forget.
Not sure what you want to change. Do you want the Paper Size to be 7 1/2 x 9 instead of 8 1/2 x 11?
Do you want the Paragraph Alignment to be Centered instead of Justified?
What is it you want it to do?
Old 06-05-2009, 05:11 PM
jal's Avatar
jal jal is offline
Okay,
Try this...
Click on the Margins on the Page Layout tab as you show in the pic.
Click on Custom Margins and, set them as you want / need.
At the bottom of that window, there should be a drop down menu where you can save the changes. The other option in this field is "From this point forward".
Use that option. It should then save the margin selection for future docs.
Hope that helps.
Also, the Help files are quite good so, give them a try. All your answers are in there. I've been using Office 2007 for a while now, and love it. Once you get used to it, it really is much more productive. Change isn't always a bad word....
`joe
Old 06-05-2009, 05:12 PM
The Broad The Broad is offline
I don't have this specific form of Office. Colleges aren't usually the newest ones to convert to anything new. However, this link should help you at least look over what is going on and how to fix it:
http://us20.trymicrosoftoffice.com/default.aspx
I have often hit the "Help" tab in Microsoft and completed searches to figure out how to change settings that are default on any Microsoft product. Often times, under Tools, you can customize your settings.
I hope this helps you. It can be very very frustrating when you can't get things to work the way you want them to.
Old 06-05-2009, 05:29 PM
Thats what I want and I want the margins to be what ever the default is. 1" around??
Old 06-05-2009, 05:31 PM
Originally Posted by jal View Post
Okay,
Try this...
Hope that helps.
`joe
Thanks Joe. I ll try it on Monday. I have work to do over the weekend and I was so fed up that I copied everything to my jump drive and left the laptop at work.
I did try the help files but got frustrated and gave up. Didnt see that "From this point forward" thing
Old 06-05-2009, 05:36 PM
Now that I look back on your settings... are you using an European version? Europeans use different paper sizes than we do here and your size sounds familiar... just wondering.
Old 06-08-2009, 10:28 AM
Okay,
Try this...
Hope that helps.
`joe
No luck. Still have the same settings no matter what I do. Very frustrated.
Old 06-08-2009, 12:14 PM
gtohunter's Avatar
gtohunter gtohunter is offline
Old Blue,
Take a look at these and see if it'll help you........you can go into help and search on template if the pic's not clear enough.
ID:	170939   Click image for larger version
Jimmy M
68 GTO
Old 06-08-2009, 01:26 PM
jal's Avatar
jal jal is offline
Alrighty,,,
Let's try this. Open Word. CLick on the "Page Layout" Tab.
Click on the small button in the lower right corner as seen in the attachment.
That will open the default page setup window.
Set your margins to whatever you need and click on the "Default" button at the bottom left.
You will get prompted with a message that basically states " Do you want to change the default settings for page setup".
Click on "Yes".
I think that will do it for you.
Let me know.
`joe
