Old 07-14-2009, 10:33 PM
TATA79 TATA79 is offline
Question 69 GTO Front Spindle Fasteners specs
Hey guys I am knee deep in Judge suspension now, and have a few questions. I have been looking in my 69 Service manual as well as my book from Paul Z. Basically the frame has been disassembled for years and I am haveing a hard time correct bolt placement. Does anyone have a good explosion with the key on the side which describes the bolts. I have one for a front drum car, but not one for the disc.
Also, when I install my zirk fittings for my new upper and lower ball joints, do the angled zirks go on top and straights on the bootom or do I have that flip flopped. Thanks for looking. dave
Old 07-15-2009, 11:44 PM
GStage1's Avatar
GStage1 GStage1 is offline
Never found an angled grease fitting on any A-body I have torn apart or dismantled in a salvage yard.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 07-16-2009, 07:31 AM
Default Greese Fittings
Thanks for that info, the only reason I ask is because a pair of the straight and a pair of the angled came with my ball joint set. I will get an additional set of straights to install.
Old 07-16-2009, 12:09 PM
webfoot's Avatar
webfoot webfoot is offline
The bolts that hold the steering arm are grade 8 and have M 96 (98?) stamped in the head, (could also just be a triangle) and are 7/16 x 2.5". There is a little step below the head. The nuts for these are clear zinc plated and are kind of beveled on top.
The bolt that goes in the big hole in the top of the spindle is pretty recognizable. It has a 7/8" head, and is grade 8 with a triangle between 2 of the marks. Bolt is only 7/8" long and 9/16" or so wide.
If you want all new, AMK products has a kit to completely assemble both.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 07-16-2009, 03:49 PM
Default Thanks webfoot
Thanks webfoot, that is exactly the kind of information I need to get this frame together right.
