Old 07-27-2009, 08:42 PM
Stormin GTO Stormin GTO is offline
Default Alum. Radiator
Anyone know what alum cross flow radiator will direct fit (bolt in) my 64 GTO with a 17.5 core support, manual trans. Both in & out on R side, what brand, part # etc. also what elect. fan works best?
Old 07-27-2009, 11:31 PM
WDCreech's Avatar
WDCreech WDCreech is offline
I put a Griffin crossflow in my '64, when they were only listed by size in Summit's catalog. Now they list "Muscle-matched" (downflow), and by dementions for crossflow. I just use a run of the mill 16", 2000 cfm electric fan, but I hear there are better fans out there.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 07-28-2009, 10:28 AM
65gto69's Avatar
65gto69 65gto69 is offline
I also used the universal fit cross flow Griffin radiator. The only thing I had to do was block up the lower rad mounts to get the radiator higher up so the upper mount would mount to the radiator.
Works great, and from what I heard the cross flows are suppose to be better for cooling than the drop.
If you are not looking for original looks I would go with the cross flow.
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 07-28-2009, 11:51 AM
my62toy my62toy is offline
I don't know where your located but I have a contact here in So. Cal. who has just finished custom making such a radiator for my 65. He also just finished one for another friend's 64. Fitted both to their exact existing core supports. Very efficient so long as you don't need/want the stock look.
Hal
http://www.vatcher.com
Old 07-28-2009, 01:11 PM
FFD FFD is offline
http://www.mark7radiators.com/ hit spec form you kinda can see what you need
Old 07-28-2009, 11:59 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
I used a northern rad race pro 19 inch for my 64, it's a cross flow 26 x 19, 19 high and 26 across. They also have a custom fan shroud kit u can buy with it. Used stock 3 core upper and lower mounts, with 2x3 aluminum tubing for a filler in the bottom, and aluminum filler channel in the top, (also northern rad supplied,). Custom fans shroud was welded together by local welder.
ID:	176380   Click image for larger version
ID:	176381   Click image for larger version
64 Lemans hardtop
4spd, buckets
