Looking for something from solid project to driver quality.
Ideal car would be a stick, deluxe parchment interior and A/C. Thanks. |
There is a decent 68 probably two hours northeast of you in plumsteadville. Original 350 car, not autumn bronze, but does have deluxe interior. You want a phone #?
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
What color?
Send via PM, please. |
Scott:
The following link is for my 1968 400 4-Speed Firebird that I posted on yenko.net: http://www.yenko.net/ubbthreads/show...e/0#Post410581 Ed |
I was watching the Steve Martin movie "The Jerk" the other day and saw a "brown" 68 in the garage scene with Jackie Mason.
If you have seen the scene, I was wondering if thats the Autumn Bronze color? Whatever it was, it was a very nice looking color, imo |
I saw this one while doing my daily search. I dont know the "brown" colors for 68 so thought I would post. Looks clean.
http://raleigh.craigslist.org/cto/1315154759.html |
Here is my 1968 Project Firebird that I will be posting in a few days. RIght now here is a partial list of all the parts. I have to add more parts and tighten up the codes but here they are for now.
NR - New Restoration NP - New Part NPA - New Part Aftermarket NOS - New Old Stock If you are interested I can let you know up front and get pics. The car has just been stripped of ALL paint and the body work has been done and primered ready for paint this spring. The car had less than 40K original miles and when you look in the doors they look like a car with 20K original miles completely solid and original. The trunk had to be replaced becuase of a race project fuel cell gone bad and the from floors were rusted from the inside out so I had them replaced. Everything is super solid. Take a look at the parts that are sitting and waiting and I still have more to add. It would have been easier for me to list the parts that werent replaced but anyways here goes. GAS TANK Gas Tank NR Gas Tank Sending Unit NR Gas Tank hose to filler neck NR Custom Tankinc.com Internal Electric Fuel Pump Assembly N Gas Tank Straps NR Gas Tank Straps Hardware NR REAR BUMPER Rear Bumper NR Bumper Bolts NR License plate Light NR Bumper mounts Restored REAR SUSPENSION Leaf Springs (5" lift) NPA Leaf Spring Bushings NPA Leaf Spring Pads NPA Leaf Spring shackles NA Competition Engineering "Competition" traction bars NPA Competition Engineering Rear shock mount NPA Monroe Coil-Over shocks NPA 1972 Nova 8.5 10-bolt with 4:10 Gears - Completely gone through with all new bearings. New Richmond Gear Set - Rebuilt by Vanderlays on the east coast Custom 10 bolt to 12 bolt cover NPA Mr Gasket 12 bolt Aluminum Finned cover RS Stainless Steel hex cover bolts REAR BRAKES Front Cadillac Rotors NA Front Cadillac Calipers NA ScareBird.com custom caliper Mounts NAP Caliper Brake Hose NA Rear Brake Hose NA Rear brake lines NA Emergency brake cables NPA Emergency intermediate brake cable NOS TIRES RIMS American Racing T71r 15x7 15x8 NPA BF Goodrich Radial TA's NPA American Racing Lug Nuts NPA DOORS All body panels have been stripped of ALL paint, body work was completed and pre-paint primer was sprayed on. Original (bird) factory windows. Original door panels Original Arm Rests Arm Rest Pads NR Rear mirrors NOS Window Fuzzies Front & Rear NR Door edge Stainless protector NR Interior Door Handles NR Exteriror Door Handles (Concourse quality) NR Door light switches NOS Door jamb vents NR All new seals for doors NR Exteriror Front "Firebird" emblems NOS Front bird emblems NOS wheelwell trim NOS Lower body trim panel NOS Rear gas tank door bird NR Trunk "Pontiac" emblems NR ENGINE 1968 Pontiac YH 370 HP 4-bolt 428 REBUILT WITH 0 MILES BOred .030 over with TRW forged pistons Stock Rods with ARP rod bolts RA oil pump 16 Heads rebuilt to factory specs with RA III valve springs New Pushrods Rhoads Lifters 7/16 Rocker Arm studs CompCams Magnum steel rockers RAM Air III equvilent cam Double Roller timing chain Pontiac Hurricane Intake Butler Racing aluminum Valley Pan GM Cast Aluminum rocker covers Holley 850 Speadbore (rebuilt) Holley Modified Chrome mechanical fuel pump (gutted for factory look) Mallory adjustable fuel pressure adapter Earls aluminum fittings and hose Mallory Unilite distributor w/vacumn advance Flex-A-Lite aluminum fan with extension NPA Mini Starter NPA flexplate SFI Rated NPA ARP Flexplate bolts NPA Power Steering Pump NR Power Steering Pump Hoses NR Power Steering pump Pully (Chrome) NPA TRANSMISSION 1968 Turbo 400 rebuilt B&M TransPak kit ???? 3500 Street/Strip converter Air-Flow deep transmission pan with cooling tubes ENGINE COMPARTMENT MSD 6A electronic ignintion amp NPA Hayden 17" electric fan NPA Hayden Radiator sensor system NPA 3 Core aluminum HP radiator NPA Factory radiator Shroud NOS Radiator and heater hose NR Heater Core NR Wiper Motor NR Wiper motor bushings NR Battery Cables NR Delco "nostalgic" battery cover NR Rear Window louvers (plastic RARE) NPA Windshield NR Back Window NR American WIre Custom wire harness (front to rear) customisable with additionl accesory capability built in. NPA Factory Radio AM/FM Conversion 45 watt per channel with MP3 input NR Pioneer 4x8 Rear speakers Speakers NR Kenwood front dual speaker conversion NR Rear seat devidor NR Sun 2 5/8 classic gauges - Oil Pressure, water temp, oil temp, vacumn, volts NPA Autometer 2 5/8 gauge angle spacers NPA Automerter 2 5/8 Fuel Pressure gauge (liquid filled) NPA Autmeter 2 5/8 cup NPA Autometer Stainless braided Fuel pressure line NPA Hood Tach (with extendted warranty) NR Front turn signal lenses NOS Front turn signal housings NR Front Spoiler (camaro) NOS Front Spoiler brakcets NR Door sill plates NR Rear spoiler (69 Trans AM style) NR Fuel lines NR Brake Lines (front to rear) NR Transmission Cooling lines NR Hurst Dual gate shifter (2nd generation Camaro/Firebird) NR SHifter cable NOS Gas and Brake pedals NR Ignition switch NR Dash Switch Bezels NR Cigarette Lighter NR Glove compartment NR Astro Vent balls NOS Astro Vent Pulls NOS Dash Pad NR Dash grip NR Dash Bird Emlbem NOS Steering Column joint NR Steering wheel - Walnut afterarket NPA Rear window mirror set NOS Dome light bezel NR Dome light lens NR Seat covers - Bucket Seats NR Seat Covers - Rear seat NR Comes with set of Ralley II wheels (off trans am) Engine stand Engine Hoist with Adjuster adapter Set of 4 wheel dollys for moving car around shop |
Forgot to mention the complete subframe was removed and media blasted and painted with POR-15. Of course new bushings for subframe, radiator support and upper fendder support. All suspension parts were treated to the same media blasting and POR-15. THere isnt a part up front that wasnt replaced except the front link (which was solid). Includes a oversize sway bar also. It has a 1969 Chevelle front disk setup with, of course, all new parts. The restored and plated brake booster and new brake unit along with new disc/disc proportiong valve mounted right next to the new wiper motor/washer unit.
That's not Autumn Bronze. |
Still looking.
Brian Baker is my love slave. |
Still looking.
Pump gas and hydraulic lifters are for minivans. |
Nice car. Horrendous wheels, though.
I'd rather restore one my way. Thanks for keeping an eye out.
see my ad, https://nanaimo.craigslist.ca/cto/5722521423.html original autumn bronze/ parchment/400/ hd 3spd/336 safety track car
69 Firebird, 462 turbo 400 3000 stall, 8.5 323 rear
Here is the Autumn Bronze. I really like this color.
https://tse3.mm.bing.net/th?id=OIP.M...=0&w=226&h=171
Sleddog, Iowa Humility is not thinking less of yourself, it's thinking of yourself less. C.J. Lewis God Bless the U.S. and the people that defend it ...
Still looking.
I think one was just posted in for sale section
Still looking.
Still looking, compadres.
