From what I can tell from the forums here, it seems that the same oil pan works for all chassis.
I have a couple of "big car" pans; and I'm able to modify to accept the five-tab rear seal. Does a '77 Firebird need a different OEM oil pan than the "big cars"? I'd like to avoid using a windage tray that needs aftermarket main cap studs/bolts to mount it. What OEM-style windage tray will fit a pan suitable for a '77 Firebird? 3/4??? Full-length??? Thanks, folks. |
The pans that came on the birds had a baffle built in to keep the oil in the sump on those better handling TA cars which the big car pans did not have.
Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill |
The pans are all basically the same, mounting-wise.
The scrapers all mount to the engine not the pan. All the scrapers (factory or factory style) will fit with all the pans. Some of the aftermarket pans may have a scraper as part of the pan setup.
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
I'd love to see photos!
Is there a distinct preference for the full tray over the 3/4 tray? |
The GM Pontiac parts catalog lists the same replacement part # for all models 76-81.
Stewart
I have an extra 3/4 tray in great shape. I'm going with the full length tray but only because I have it. Stewart
