Old 09-13-2009, 11:42 AM
Trans-Formula II's Avatar
Trans-Formula II Trans-Formula II is offline
Default What bolt holes?
I am switching from 4 speed to auto, a TH400 to be exact, what bolt holes for the tranny crossmember in the frame? Is the driveshaft the same length. I know that the yoke is different. Thanks. The engine is not ready yet, so I am trying to do as mutch as possible while it is warm.
Old 09-14-2009, 06:12 PM
Red face
Wow, so no one has a Th-400 in thier car, thanks alot everyone.
Old 09-14-2009, 06:57 PM
Ron Landis's Avatar
Cool I believe...
the crossmember slides back to the rear set of holes. The driveshaft lengths differ as do the yokes. Later ['71+] four speed yokes are the same as 400TH. The '69 Muncie yokes are the same as a 350TH. Good luck. Ron
Old 09-15-2009, 10:56 AM
69goatboy's Avatar
69goatboy 69goatboy is offline
Are you in need of anything else for your conversion? The reason I ask is that I'm doing the opposite conversion and have almost all of my AT parts still from my 69 goat.
The joker in the deck keeps sending me his card.
Smiling friendly, he takes me in.
Then breaks my back in a game I can't win.
Old 09-15-2009, 11:14 AM
robz's Avatar
robz robz is offline
Driveshaft on TH400 is shorter than 4 speed...(don't have exact measurements)...
1969 GTO 400-4speed, H/T
1969 Grand Prix SJ
Old 09-15-2009, 09:15 PM
No, I had to sell all the 4 speed to buy all the auto stuff.
Old 09-15-2009, 09:17 PM
Oh wait, yes, I need to know what set of bolt holes in the frame are for the TH400. ????
Old 09-15-2009, 11:10 PM
Roadbuster's Avatar
Roadbuster Roadbuster is offline
I think Ron is right. That is the way it is on my car.
Jon
1968 GTO with SC&C Suspension
Old 09-16-2009, 12:55 AM
cuz68's Avatar
cuz68 cuz68 is offline
What kind of shape and miles is on the tranny and trk converter? Thank you Randy, And what is the price on them?
Old 09-16-2009, 05:32 AM
Talking
Thanks Ron, I will try that.
Old 09-16-2009, 04:59 PM
69goatboy's Avatar
Hard to say without opening it up, but I believe the tranny is original to the car. The odometer reads 37k. The way the rest of the car was when I got it, I'm assuming there's a 1 in front of that figure in reality. I bought the car as a semi-running project car, so I've never driven it to know what condition the tranny is in.
The engine was swapped out at some point, so I have no idea what the converter is. I'm assuming a worn out stock variety.
I also have the rest of the goodies: (pedals, tranny cooler, a very good original black console (no lid), a ralley shifter w/knob, drive shaft).
I've no idea what a used TH-400 goes for.
Old 09-16-2009, 05:33 PM
marauder's Avatar
marauder marauder is offline
I'm doing the opposite conversion as well and will be looking to get rid of the following if you're interested in an OD tranny.
7004R with a performance rebuild, 5000 miles since rebuild
B&M Racing Holeshot 2400 converter
Pontiac adapter plate
TCI flexplate
Summit deep alum tranny oil pan
Driveshaft
Curt
'69 GTO Ragtop, 455, RA, KRE SD Perf ported heads and "old Faithful" cam, Sean Murphy Q-Jet, Tremec 5spd, Moser Trutrac 3:73, Hotchkiss, Speedtech, Wilwood
'64 Lemans Convertible, Tremec TKO600
Old 09-16-2009, 05:35 PM
Ken K Ken K is offline
Use the last bolt hole in the rear. There will be 2 unused bolt holes in the center and the next bolt hole will be for the front bolt.
ID:	181477   Click image for larger version
ID:	181478   Click image for larger version
