Old 11-19-2009, 04:04 AM
dlarkins's Avatar
dlarkins dlarkins is offline
Default Heater surge check valve-Which one is correct ?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=360114322972&ssPageNam e=STRK:MEWAX:IT
See link above... I have different kind of surge/check valve I bought off a fellow PY forum member. It installs in-line from the water pump to the core inlet.
This one on EBay is on the RH head. Is one better than the other ? I would think one is on one side of T-Stat than the other...no ? In other words one would be on inlet and RH head is outlet (is RH outlet ?), so how could it prevent a surge on the outlet side...?
I'm rather curious...
dave
'65 GTO Hardtop
389 .030 400ci Tri Power, .068 cam, HO manifolds, M-20 4 SPD, '70 12 Bolt 3:36 Chevrolet posi-traction, Montero Red, Parchment gut, VINTAGE AIR, PFDB, Bilsteins, F&R HD Sways, Hotchkis rear bags, Firestone Indy 500 shoes
"What's the point of owning a muscle car if you can't scare yourself stupid from time to time ?"
Old 11-19-2009, 04:32 AM
dlarkins's Avatar
I found alot of posts on this issue...
http://forums.maxperformanceinc.com/forums/showthread.php?t=516510&highlight=core+restrictor
BUT...which is BEST ?
1) nipple from head to inlet w/ check vale
2) In-line restrictor per mod in Restoration Guide
3) Crimping the inlet
I'm confused....LOL
dave
'65 GTO Hardtop
Old 11-19-2009, 04:06 PM
67 Lamnas's Avatar
67 Lamnas 67 Lamnas is offline
There isn't a "best".......It's a matter of hydraulics.....There will always be a pressure drop when there is flow past a restriction or orifice......
Whether the restriction is the cylinder head nipple, in-line restriction/orifice, or "crimping" the inlet.....doesn't really matter.....
