Old 01-21-2010, 09:24 PM
Mike Pemberton Mike Pemberton is offline
Default Reclining seat Positioning unit
Need some input re:
How does it operate?
Combination of spring pull and hydraulics or just spring pull?
Seems to be bound up. Neither shaft moves at all.
Have it soaking right now to see, there may be some internal issues with rust I cannot see.
It does not appear to have any issues EXCEPT it won't actuate.
The cable is fine as well as the trip mechanism that is attached to the "positioning" unit as it is called in the book. The plunger shafts that you can see from where the trip notch is are shiney and smooth with no signs of rust or pitting.(PICTURE # 3)
Any help here guys?
Pictures attached.
Thanks,
Mike
Name:	Positioning unit 1.jpg
ID:	194672   Click image for larger version
Name:	Positioning unit 2.jpg
ID:	194673   Click image for larger version
Name:	Positioning unit 3.jpg
Old 01-22-2010, 01:50 AM
Default Never mind and Thanks
Rolled up the sleeves and gotter done !!
Mostly just some minor clogging, rust, paint, media material from when the seats were medial blasted for paint.
Soaked the crap out of the unit with carb cleaner(good paint stripper) wd40, tool oil, white lithium, liquid wrench, ANYTHING in the cupboard that I thought would help.
Here is what I found.
It is just a spring mechanism.
I started by twisting the male shaft(no comment) until it broke loose a little and just started working it until I got it to rotate in place, little by little got more movement until I got the spring plunger to operate correctly.
Re flushed 2x's more then the final lube, wipe down and re install into seat.
Pictures attached.
Mike
Name:	Positioner done 1.jpg
ID:	194707   Click image for larger version
Name:	Positioner done 2.jpg
Old 01-22-2010, 03:00 AM
wheelspin's Avatar
Smile Good sleuthing......
Nice goin', Mike. I knew that your persistence would pay off in the long run .
Les
Les Iden
Old 01-22-2010, 03:07 AM
Default Thanks
Helps when you let the brain f a r t s pass and you can clear your head to think.
Just getting tired of these challenges that keep poppoing up all the time.
Mike
Old 01-22-2010, 12:00 PM
Mark Simiele's Avatar
Mark Simiele Mark Simiele is offline
Good work on the seat. Now you are probably the expert on reclining seat refurbs and I know where to send mine! Everything looks terrific and keep those pics coming.
69 GTO convertible Warwick blue w/parchment, 400 4bbl auto trans, #'s matching, frame off resto w/ 36 options and more coming.
67 Bonneville 428 convertible one of one Verdoro green w/parchment, documented GM brass hat parade car with every option for 67, non running MAJOR future project.
Old 01-22-2010, 01:27 PM
Old Goat 67's Avatar
"Ain't no hill for a stepper", right Mike?
Old 01-22-2010, 03:50 PM
Default Can't afford me !!
Knowing what I know now, you best call me and I will tell you how.
Lets see ??? Shop rates----$75.00 per hour----- 2.5 hours on just the actuator----$187.50 just for the spring/thinngie to work right.
If I had to pay for all this crap I would never be able to finish this car.
Mike
Old 01-22-2010, 03:52 PM
Default Thanks for the push !!
Hills OK
Effin BS crap that I don't expect is wearing my sneakers thin !!
Gotta keep on keeping on, getting too close to being finished.
Mike
Old 01-22-2010, 10:03 PM
Sounds like the early units aren't much different from the ones they used in the mid 90's.
Mike
former." --Albert Einstein
- Winston Churchill
Old 01-22-2010, 11:28 PM
Default Mid 90's ????
Mike
Never had one apart, I didn't know anyone built cars past 1972 !!
Mike
