Old 03-22-2010, 08:12 PM
pontiac6269's Avatar
pontiac6269 pontiac6269 is offline
Default Chevy truck conversion
I have a 81 3/4 ton 2wd. I want to convert to 4wd. Local yard has a 84 1/2 ton 4wd. Said if I pulled the body I could have the rolling chassis minus engine for $500. This includes front and rear ends(3.08 gears), transfer case, Trans(700r4), drive shafts and any miscallaneous parts I may need. I don't know how clean the frame is, haven't looked at it close enough yet. I was wondering if the 1/2 ton parts would bolt onto the 3/4 ton frame if the 1/2 ton frame is bad?
Thanks, Eric
Eric
1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60'
1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85
Old 03-22-2010, 09:03 PM
steve v's Avatar
steve v steve v is offline
There's quite a bit of difference between 2wd to 4wd frames, mainly the front cross member under the engine. They are riveted together from the factory & takes some work to convert.
I think the trans tunnel is also different from 2wd to 4wd. You'll need the 4wd tunnel & have to do some cutting/welding on your floor boards to to the swap.
You'd be better off in the long run buying a 4wd truck & sell your 2wd.
Old 03-23-2010, 06:38 AM
Keith Seymore's Avatar
I think Steve's right, but you might also post your question over here:
http://67-72chevytrucks.com/vboard/forumdisplay.php?f=4
Good bunch of guys who may have already done such a swap.
K
'63 LeMans Convertible
'63 Grand Prix
Old 03-23-2010, 10:49 PM
74gto's Avatar
74gto 74gto is offline
I've done the 2wd to 4wd cab conversion as mentioned here. not too bad, but the center part of the 4wd floor is higher and would have to be welded into the 2wd cab floor.
Up until last year, I had a 77 chevy 4wd frame with axles and transfer case I had a hard time getting rid of. It sat for 2 years with no takers. JOHN
74 GTO 406 T400
74 Firebird 350 4-speed
68 GTO Convertible 400 T400
76 GP LJ 400 4BBL T400
78 Chevy 1/2 Ton Truck
Oh yea I love my wife very much
For some reason it got erased when I put it here last time!!!!!! hmmmmmmmm
