Old 04-17-2010, 02:22 AM
Mikes455Wagon's Avatar
Mikes455Wagon Mikes455Wagon is offline
Default Went to the track tonight....
Well we finally got the car together and got to the track tonight. It's only an 1/8th mile track and its up on the mountain so the air is terrible but the times were pretty good. We had some issues associated with the vacuum advance on the distributor so we ended up unhooking it and running only mechanical advance and 38 degrees total timing. My combination is a 455 .30 over, xe 274 cam, 062 heads with good valves and springs and gasket matched with no port work. Torker 1 intake, 750 carter competition series carb, th400 with a 10" continental converter and 3.73 rear gears with a 28x9 hoosier slicks. The first three passes with the car falling on its face were 8.30-8.40 passes with 1.80 short times. After fixing the timing issue the car totally came to life. The converter just plain WORKED also! Thanks Cliff for working with continental and getting me just what I needed. The next pass the car went 7.74 with a 1.61 sixty foot with the left front tire up in the air pretty good and followed it with a 7.62 with a 1.59 sixty as the air cooled down. All and all I am very pleased with how my ol unported cast iron headed motor runs. Hopefully we are VMP bound in a Pontiac Powered BUICK WAGON....and maybe tomorrow night I will get the video of the last pass posted..
Old 04-17-2010, 06:56 AM
hal101's Avatar
hal101 hal101 is offline
cool sounds like it is running good
Old 04-17-2010, 07:40 AM
gold bird's Avatar
gold bird gold bird is offline
Thumbs up
nice runs with a EX 274 cam , what do you shift at ? good job and have fun .
1978 ,t/a 3660# 455 2010 / 1/8 7.86 1/4 12.40 @ 109,19
http://www.youtube.com/watch?v=6PaHbLnszS0
http://www.youtube.com/watch?v=XMxhM...eature=related 12.01@109
http://www.youtube.com/watch?v=MC-dganA2jQ 100 shot 11.78. A,ll new head cam combo 96 ported bye Mike Chell!! Comp cam yes the 284 XE. Firsthand outing of the street 7.69 1/8 12.15 109.47 hot and humid.not hooking. 1.73 60.
Old 04-17-2010, 07:48 AM
Cliff R's Avatar
Cliff R Cliff R is offline
"Thanks Cliff for working with continental and getting me just what I needed. The next pass the car went 7.74 with a 1.61 sixty foot with the left front tire up in the air pretty good and followed it with a 7.62 with a 1.59 sixty as the air cooled down."
You are welcome! Great 60' times for the combination of parts, quicker than my own car, best I've managed to date is 1.61. Let us know how it runs in the 1/4 mile? I see potential for high 11's with some good air......Cliff
Old 04-17-2010, 09:05 AM
johnta1 johnta1 is online now
Congrats on the ET's.
Sounds like you have a good combo.
Old 04-17-2010, 09:40 AM
66bonne's Avatar
66bonne 66bonne is offline
Those are some great times for your combo, very impressive. I really like those 60footer times. Good job. Iron block, iron heads - that's sweet.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8.
Old 04-17-2010, 09:57 AM
tc's Avatar
tc tc is offline
Wow. How do you and other's car's run so good. I know someone with a 455, xe284, unported d-ports, ran a 7.48 in the 1/8 mile. My car has run 7.63, and that is with a 1.73 60 ft. Guess I need to do more work. Some of your of parts are certainly not recommended on this board. Great job, hope it goes quicker. Looking forward to the video.
Old 04-17-2010, 10:02 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Nice runs for sure.
What is the weight?
What gear?
Old 04-17-2010, 10:11 AM
grandville455's Avatar
grandville455 grandville455 is offline
Yes Excellent times!.. what size stall conv?
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 04-17-2010, 10:16 AM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
Now you see why "Wagons" have the hook advantage from the weight transfer! Your last run calculates +- 11.96 in the 1/4. I'm surprised to see it took 38 total timing though, most combo's similar to yours generally like 32-36 degrees. But every combo is unique. Congrats!!! JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
Old 04-17-2010, 11:26 AM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
I set of unported 225CFM D-Ports can make 1 horsepower to cubic inch on a 455ci. That can push a 3600lb car into the 11's.
Calvin Hill
Hill Performance
708-250-7420
Old 04-17-2010, 11:59 AM
rtanner's Avatar
rtanner rtanner is offline
7.60 what with a 1 what sixty foot, using a comp xe 274 cam, and a old ##s torker 1, psha I say psha and bah hum bug to! And stock heads, my god man don't you realize the possible repurcushions of such actions! That performance w those parts goes against the actual thread of the fiber that's holds the entire Pontiac community together! Oh wait a minute I see you actually used the community specific torque converter! So never mind the torque converter is why your so fast! Ok good job! But watch your parts selection in future young man we run a tight ship around and deviating from the community plan is fround upon! Hahahaha lol! I'm in a good mood today just joking around guys! And that is excellent performance and thanks for sharing
The Following User Says Thank You to rtanner For This Useful Post:
Old 04-17-2010, 12:05 PM
[QUOTE ] The next pass the car went 7.74 with a 1.61 sixty foot with the left front tire up in the air pretty good [QUOTE]
we will need pics of that
Darby
Old 04-17-2010, 12:09 PM
rtanner's Avatar
Oh I almost forgot, and that car better have a quadrajet on it!
Old 04-17-2010, 12:40 PM
Thanks everyone, I am very pleased with the combination. I stalled it at about 2800 seemed to be where it left the hardest and the converter is a 10". Any more than that you will have to ask Cliff because converters are still somewhat of a mystery to me. When i get back to my windows based desktop I will put the video up even though my dad seems to need some video camera training but its still a decent clip. I was shifting the car at 5300 and that seems to be where it went the fastest. The timing we are going to play with a little more once we get to VMP. Probably wont be competitive there bracket racing because we don't have much time on the car at all, about 10 passes, the first 3 broke the th350, and the last 7 last night on the new 400. The motor still has the break in oil in it at this point and not much run time so as the rings seat in it might pick up a little more.
Old 04-17-2010, 12:44 PM
wow that has to be a pretty loose convertor!..i think my own conti. will start pushing the car around 2500? i will see tom. i know it will go to 2000, u must have the 4200 conti? mine is a 3200 restalled to 3800 suppose to be anyway. What does car weigh? Either way looking forward to vids!.. and great performance with a xe 274 wow!
Darby
Old 04-17-2010, 01:56 PM
The car weighs about 3500 lbs with me in it. The car got stripped and In some ways it got lighter but then as stuff like a roll bar and box steel cross member got added along with the 9" rear the weight came back. At about 2900-3000 the car wants to do more than the brakes will hold. With the xe 274 cam I have a torque monster more than likely in the amount of cubes I have. When I get back over the hill to my house from the parents I will try to get the video up. Like I said earlier, dad is a better engine builder than camera man. Guess I will have to take mom next time to operate the critical camera....
Old 04-17-2010, 02:23 PM
ta man ta man is offline
Wow 3500lbs .. that is a sleeper for a wagon.Those heads are they 062's or 62's.
Old 04-17-2010, 02:33 PM
62s from a 69 428. The motor has a stock crank, Cat Rods, and speed pro forged pistons that are flat tops so I am running a good amount of compression. The cranking compression numbers were around 220 and some of that is probably thanks to the baby camshaft i am running.
Old 04-17-2010, 08:47 PM
Here is a link to the 7.62 pass, the quality of the video went down when I loaded it so I need to work with my software a bit still....
http://www.youtube.com/watch?v=knini1yilP8
And a walk around of the car with it running....
http://www.youtube.com/watch?v=MBlXeQV6O5Y
