Old 05-28-2010, 10:52 AM
chiefshoe chiefshoe is offline
Default knocking in my head
Ok I had my #16 heads rebuilt, and I have a knock in either the #2 or #4. I have changed the rockers, lifters, cam and rods twice and the problem is still there. So I was looking at the studs and the #4 intake stud is higher that all the rest, could this be my problem? Is so, how can I push the stud down further without causing damage. If this is not the problem what do you think it is?
Jim
Old 05-28-2010, 11:30 AM
ARAMP1's Avatar
ARAMP1 ARAMP1 is offline
Does the problem come and go/different with engine temp/rpm?
You say knocking, but usually connecting rods knock and the valvetrain taps (the way I describe it anyway).
Old 05-28-2010, 11:45 AM
Yes tapping would be a better word. It goes along with the rpm if the rpm is higher the tapping is faster.
I thought it could be spark knock but when I pull the plug wires the tapping is still there.
Old 05-28-2010, 12:26 PM
robz's Avatar
robz robz is offline
Could also be exhaust leak (especially if you have headers)....
1969 GTO 400-4speed, H/T
1969 Grand Prix SJ
Old 05-28-2010, 01:14 PM
Ollie's Avatar
Ollie Ollie is offline
Jim
Yes, if one stud is higher it is pulling out. You could try tapping it down but there is no guarantee that it will not pull out again. The old school repair is to drill through the stud boss and stud then tap in a roll pin. Or remove the heads and take them to a machine shop and have threaded studs installed.
Its ok to giggle and snicker, Dont laugh and point
Old 05-28-2010, 03:37 PM
I pulled it apart and tried the two different torque techniques the tight then 180 and the 20foot pounds. But to no avail it still there, it’s driving my buddy crazy. I have placed the stethoscope everywhere I can’t find it. I will look for an exhaust leek
Old 05-28-2010, 05:28 PM
rememberfireball#22's Avatar
rememberfireball#22 rememberfireball#22 is offline
I know now I was informed wrong, but I have always thought the 16 heads had screw in studs.
Old 05-28-2010, 05:51 PM
webfoot's Avatar
webfoot webfoot is offline
Thats what I thought too but evidently there were some later 16 heads which did not.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 05-28-2010, 05:53 PM
Ducks Goat's Avatar
Ducks Goat Ducks Goat is offline
I think the '68 and '69 16 heads are big valve, screw in studs, but the 16's made in '70 were small valve, press in studs.
1999 WS6 Formula, 1 of 175
1967 GTO Linden Green 4 spd, A/C, survivor
1967 Lemans convt
1967 Firebird 400 bench seat, deluxe interior, auto
1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, [email protected] (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne.
1961 Catalina 2 door htp
1960 Ventura 4 door htp wife's car
1960 B'ville 2 door htp
1960 Catalina Wagon wife's car too
Old 05-28-2010, 06:54 PM
These are a set of 70 heads I have on a 68 HO is there any way it could be in the springs?
