Old 05-30-2010, 01:54 PM
knauert1's Avatar
knauert1 knauert1 is offline
Default headlight switch
Does anyone know the best way to verify if the vacuum headlight switch is good or not on a 1968 GTO with hideaway headlights
Old 05-30-2010, 01:59 PM
knauert1's Avatar
Default Hidden headlight actuators
Does anyone have advise on what to lubricate the vacuum actuator piston in the hidden headlight actuator on a 1968 GTO, it does go up and down with shop-vac vacuum but it seams that if it were lubricated (grease, vaseline, oil) that it would work smoother,
thank you
Tom
Old 05-30-2010, 02:03 PM
knauert1's Avatar
Old 05-30-2010, 02:04 PM
knauert1's Avatar
Default hidden headflight actuator
thank you
Tom
