Old 06-01-2010, 09:57 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
Default Upgrading to TH 350
I've finally decided to change out the ST300 tranny in my 65 for a TH 350. Here is my checklist:
Tranny
Torque Convertor
New Dipstick
Shiftworks conversion kit
I like to have all my parts before I start a project. Anything else I'm going to need?
Old 06-01-2010, 10:44 PM
fyrffytr1's Avatar
Just curious, why a TH350?
Old 06-01-2010, 11:05 PM
chipster's Avatar
chipster chipster is offline
Detent cable and brackets?
Old 06-01-2010, 11:34 PM
ron cozzo's Avatar
ron cozzo ron cozzo is offline
Yep, the kick down cable and bracket is the toughest part. I think Lokar makes a universal. When I made the same switch in my '66 years ago, I found a bracket and cable to use in the junkyard, can't remember from what.
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc.
'02 Firebird, V6, auto
'68 GTO Convertible, HO, 4spd, driver
'66 LeMans Hardtop, 400, FI, A/C, 4L80E.
'65 GTO Hardtop, restoration ongoing
'64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue.
http://www.gtoaco.com
Old 06-02-2010, 07:12 AM
chrisp chrisp is offline
Shiftworks conversion kit , you do not need , reuse your trans. linkage and bend the shifter stop at the end 1/4' back for the extra gear . Did the same conversion in my 65 15 years ago still works great . Save your money .
Old 06-02-2010, 08:26 AM
Andre's Avatar
Andre Andre is offline
I made this change out about 15 years ago on my '64. replaced the trans about 3 years ago. In retrospect, I should have gone iwth the 200r4 the second time around
Old 06-02-2010, 01:43 PM
Jerry H.'s Avatar
I'm not running a kick down on the car now (2x4 setup), is it something that I positively HAVE to have? If I want to have a 'passing gear', I can manually pull it down into 2nd gear.
Old 06-02-2010, 01:46 PM
Jerry H.'s Avatar
I forgot to mention I have a column shift car, so I wanted the corrected lens with the D, 2, 1. I also got a 'kugel' kit from them that has an adjustable rod and shift arm that is supposed to put your pointer right on the numbers. I may not need it, but I'll have it just in case.
Anything else I'm missing?
Old 06-03-2010, 09:34 PM
FFD FFD is offline
What kind of dip stick you looking to get or have
Old 06-03-2010, 09:49 PM
Jerry H.'s Avatar
Looking to get the TCI-743860. It claims it a universal dipstick for GM trannies.
Old 06-03-2010, 09:50 PM
Jerry H.'s Avatar
Because it is supposedly a direct bolt in. No moving the crossmember, no changing the tranny yoke, etc.
Old 06-03-2010, 09:54 PM
fyrffytr1's Avatar
Now we know the rest of the story. Thank you for that tidbit.
Old 06-03-2010, 10:49 PM
65lemans's Avatar
65lemans 65lemans is offline
No to auto's !!! 4 SPD. IT'S A MUSCLE CAR !!!!! WTF !!!!! MY GOD !
Old 06-03-2010, 11:02 PM
Question
Okay, now please answer this question:
What if a musclecar owner happens to be disabled and can no longer drive a manual shift car?
Old 06-03-2010, 11:13 PM
Jerry H.'s Avatar
Exactly why I own an automatic!
Old 06-04-2010, 08:23 AM
chipster's Avatar
Me too, I only have one leg, so it's pretty tough for me to drive a 4-speed, not to mention dangerous and illegal. "Automatic Drive Only" is stamped right on my driver's license .
Old 06-04-2010, 10:01 AM
dbiggs dbiggs is offline
Put in a BOP TH350 in my '66...no mods needed. Same driveshaft.
Resto almost done - 1966 GTO HDTP Tiger Gold (paint code 1-2), black vinyl top and interior, 389 tripower, 068 cam, TH-350/Hughes TC, RA manifolds, 2.5" Pypes exhaust, Scarebird Front Disc, Ralley II's, factory PS, PB, PW, PA, A/C, headrest option.
Old 06-04-2010, 11:20 AM
Keith Seymore's Avatar
Good answers, guys.
The only other alternative is the car gets parked and sits for 25+ years (which is what happened in my dad's case).
K
'63 LeMans Convertible
'63 Grand Prix
Old 06-04-2010, 11:21 AM
I'm leaning in that direction too, Andre.
After putting a TH400 in my Grand Prix, I'm hearing the 200R4 is a better fit - and - one more (overdrive) gear would be nice.
K
'63 Grand Prix
Old 06-04-2010, 03:45 PM
Andre's Avatar
The 200r4 bolts up without an adapter, but the crossmember would have to move. I think by now they probably have an adapter so you don't have to move the cross member. (at leas I hope so, especially for a drop top) The better low gearing, and the overdrive at highway speed is the advantage.
The 200r4 isnt for big torque high hp engines, but would have been just fine behind my 325hp 64 GTO. I could be doing 70mph at 1900 rpm. :-(
