Old 06-29-2010, 05:50 PM
463gtojl 463gtojl is offline
Default 1968-1972 Rear Window Trim
Hey guys, I would like to know if the rear window trim for 68-72 GTO's are all the same? If so, do any of you guys on here have any laying around? I need one for a 1968 GTO. Thanks. I seen the ones on Ebay but they are over $200...
Old 06-29-2010, 05:58 PM
webfoot's Avatar
webfoot webfoot is offline
68-72 A-body is all the same. Someone may have a set in here but there is also a "wanted" section of the forum which you may have better luck.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 06-29-2010, 06:05 PM
I wouldnt say "A body" because the shop where the car is at, the owner has a 1972 Chevelle and the trim isnt even close... He was just going to give me his but it does not fit.
Looks as if it will have to come from a 68-72 GTO. Thanks though
Old 06-29-2010, 06:46 PM
marxjunk marxjunk is offline
i have a set pretty decent 100 bux plus shipping..off a 68
Old 06-29-2010, 06:57 PM
You have PM
Old 06-30-2010, 03:35 PM
Originally Posted by 463gtojl View Post
You have PM
pics and pms returned..
Old 06-30-2010, 11:30 PM
68pongto's Avatar
68pongto 68pongto is offline
I think it is also just 68-72 GTO, Lemans, Tempest 2-doors. 4-doors different. I know Cutlass is different, and I think Chevelle too, its been some time since I compared the two.
Old 07-01-2010, 01:19 AM
codyyy's Avatar
codyyy codyyy is offline
I'm not real sure, I took all the trim from a '68 Tempest 4-door at the junkyard because I might need spares or whatever, it looks like it will line up. At like 45 cents a piece I couldn't go wrong.
Old 07-01-2010, 12:05 PM
68pongto's Avatar
I have a 4-door, It's different, it won't line up.
Old 07-01-2010, 12:11 PM
codyyy's Avatar
Will any individual pieces line up or just the whole thing won't?
Old 07-01-2010, 01:48 PM
i shipped your moldings Jimmy...
Old 07-01-2010, 10:02 PM
68pongto's Avatar
4-door rear window trim is squared off in the upper corners, the lower corners have big curves. None of it interchanges with 2-door!
Old 07-01-2010, 10:57 PM
it does if you have a hammer....
