Old 06-29-2010, 10:15 PM
67cruiser 67cruiser is offline
Default What makes Temp lite come on when???
I put my headlights on and temp. light comes on, i am running a mech. gauge, i see ware the wire should hook on the temp sending unit but i do not have one. Do i have to ground this wire???? Whats the easiest way of doing that??
Old 06-30-2010, 03:43 AM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
if your saying the temp dummy light in the dash cluster is coming on with the headlights then id say look at the light sockets and make sure you dont have a regular dash light in the temp lights hole
Old 06-30-2010, 07:06 AM
2002Z4CSS's Avatar
Sounds like a poor ground for the dash or some power is back feeding. The circuit for the temp light is normally open and the sender grounds it when the engine is hot. If you don't use the bulb anyway, remove the bulb.
1971 Pontiac GT-37
Old 06-30-2010, 04:07 PM
ok, what dash bulb should be in the temp cluster in the dash??
Old 06-30-2010, 09:05 PM
Performer, why didn,t i think of that?? makes sence to me???I cannot spell either!!
Old 07-01-2010, 07:40 AM
2002Z4CSS's Avatar
Usually the bulb is directly behind the lens for the temp light.
1971 Pontiac GT-37
