Old 07-03-2010, 11:06 AM
motor29's Avatar
motor29 motor29 is offline
Default Brake dragging
I just finished a front disc brake conversion. Everything up front is new power booster, master cylinder, hoses, lines and hardware. The driver side caliper is dragging , I had a very hard time bleeding the brakes. The passenger front works fine , I even replaced the master cylinder and caliper and it's still dragging. HELP, any suggestions would be very appreciated.
"One dog is goin one way , one dog is goin the other, the guy is looking like what do you want from me"
Old 07-03-2010, 01:05 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
Sounds like trash in the line somewhere or the perportioning valve. Did you blow out the lines before installing the new parts?
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
Old 07-03-2010, 01:27 PM
motor29's Avatar
No but I see myself doing that in the near future.
Old 07-03-2010, 02:04 PM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
Was this a kit?? I have seen that preloaded calipers are much easier to use out of the box, then the ones that need bleeding.
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 07-03-2010, 02:19 PM
motor29's Avatar
Yes this a kit from Tom's classics bought off Ebay , the price was reasonable and their feedback was excellent.
Old 07-03-2010, 02:23 PM
The only reason I ask is that I used the Scarebird kit. Were you get the parts your self. You can get DOA parts from Napa etc.. If it is from a kit you are probably ok as the parts are probably guaranteed new.
The Burb Files
Old 07-03-2010, 03:36 PM
LPete LPete is offline
If you open the bleeder screw and the drag goes away, it's something causing pressure to remain in the system -- if not, it's a mechanical problem with the caliper.
A little drag on a disk brake is normal.
Lee Peterson
"I didn't expect a kind of Spanish Inquisition...!"
'69 Cameo White RA III Judge, 4 speed, owned since 1977 -- my first car.
Old 07-03-2010, 04:21 PM
motor29's Avatar
I bled the front drivers side again and also the proportioning valve. When I lock up the brakes the passenger side leaves a thick black skidmark and the driver side skidmark seems to be half as light but no more dragging ? WTF
Old 07-03-2010, 10:26 PM
n20ta2's Avatar
if the dragging is gone you may just need to put a few miles on the car for everything to take a good seat.Unless you feel the car pulling one way on hard braking.
Old 07-04-2010, 06:00 PM
antique69lemans antique69lemans is offline
Check the soft line at the caliper on the problem side. I have seen them act like an orifice or check valve. Sometimes you can't tell from looking at the outside that they are bad. Swap sides with the hoses or replace that side and test again. If you have a helper to work the pedal, you can loosen the connections one at a time closest to the master and work your way out and observe fluid flow.
Old 07-04-2010, 06:16 PM
Bill93711 Bill93711 is offline
I had a similar issue. First found that the rod between the booster and the master cyl was too long. Cut it off a bit. Still some drag on one side. Found that the plunger on that side was a bit longer than the other. Machined this down a bit, seems OK now. Thanks IN LINE TUBE for a great kit.
Old 07-09-2010, 09:36 PM
motor29's Avatar
Well I drove the crap out of the car the other day seems to be working better after bleeding the front again. Thanks for all the advice.
