Old 07-16-2010, 12:10 PM
67 Lamnas's Avatar
67 Lamnas 67 Lamnas is offline
Default Need some quiet gears
I have a Moser 12-bolt with aftermarket 3.90 gears......they are noisy as hell (or else I'm just too picky), so I'm thinking of either going to some OEM gears.....but then I'm limited to a 4 series gear ratio, or else maybe I go to a different brand of after market 3.90 that are quieter.
I spoke briefly with Cliff Ruggles and he feels like a 4.10 would be too much gear for my combo.......
Dunno what to do.......Cliff says he has had best luck with US Gear, but I don't think that brand is still made in the USA.....quality has probably degraded since then......
What brand have you guys had good luck with?
"XE cam basher"
Old 07-16-2010, 12:25 PM
Kyflier Kyflier is offline
I've got a set of 3:90's at home, still in plastic, but don't know the brand or the series they are. They are for a 12 bolt
Kenny
Cincinnati, Oh
1971 Ventura II
400 .060 Eagle Rods
Old 07-16-2010, 12:45 PM
I havent had noisey Richmonds but an old "Zoom" set I had whined no matter how you set them up. Are you sure the noise isnt other differential components?
Old 07-16-2010, 01:03 PM
67 Lamnas's Avatar
Why don't you get a look at them and let me know what they are.
I won't be "sure" until I pull it apart and look....
"XE cam basher"
Old 07-16-2010, 01:28 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
I have Yukon 4.56's in my truck. Been in there 3 years & many miles. Did the 2007 Power Tour right after I installed my setup. Did 2800 miles in 8 days. Never a peep. I'm critical myself when it comes to noises, too. My GTO has plenty
Not sure what you mean by noisy. Maybe the rear diff isn't set up correctly (tolerences). Could be a bad carrier bearing or even a pinion bearing. Even an axle bearing could be noisy.
Maybe give us a little more info IE when they are noisy - off/on the throttle, cold/hot, etc.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
Old 07-16-2010, 03:20 PM
73FIREBIRD's Avatar
73FIREBIRD 73FIREBIRD is offline
Try Motive gear. They have them in 3:90 I have set up many 12 bolts with these gears & are not noisy. They are a good gear set & I think you will like them very much. They are around $210.00 for the set at Summit
Old 07-16-2010, 03:58 PM
67 Lamnas's Avatar
Motive Gears are what's in there now....it must be the brand that Moser put in most all their 12-bolts.....I'm not happy with them......
"XE cam basher"
Old 07-16-2010, 04:33 PM
73FIREBIRD's Avatar
Then you need to check the set up on them as they have been very quiet for the people I have done rearends for. Do they make more noise under load or on the coast side of the gear?
Old 07-16-2010, 04:41 PM
punisher#1's Avatar
punisher#1 punisher#1 is offline
i have also has good luck with the motive stuff.
they have a line called "stock performance" it is made from the same material that their other gears are made from but the surface finish is much better. i don't know if they have that ratio for that series carrier but you should check them out.
'78 Ford Fairmont 526ci pontiac; true 10.5 tires and stock suspension.
5.14 @140.5 w/nos; 8.86@151 all motor.8.17@172 1/4 mile w/nos
Old 07-16-2010, 04:55 PM
Tom Vaught's Avatar
Boost Engineer
Most noise or lack of it is based on how the gears are "lapped" together during the production process. Ford's Sterling Axle plant used to make very quiet 9" Ford 3.90
gears.
The GM stuff, who knows. probably if it has all of the teeth on the pinion and ring gear during the process they call it good.
Tom Vaught
Old 07-16-2010, 05:51 PM
Superchief455's Avatar
Superchief455 Superchief455 is offline
gears.
Tom Vaught
Ford Engineers.......lol......should'nt you be working on a supercharger or something instead of picking on GM......Geez....
Heard alot of guys who have bought "stuff" from Moser and have complaints of this nature no matter GM derived or Ford. Had a buddy with a 9 inch in a 3rd gen camaro and that thing howled like a stuck pig from start to stop till i tore it apart and well i'll just stop there as that's enough said....
Old 07-16-2010, 06:21 PM
Tom Vaught's Avatar
Boost Engineer
I will repeat my statement for those who did not understand my statement:
"Most noise or lack of it is based on how the gears are "lapped" together during the production process. Ford's Sterling Axle plant used to make very quiet 9" Ford 3.90
gears."
That is a very TRUE statement. I said nothing about Moser gears in 9" ford rears, US Gears in 9" ford rears, Richmond gears in 9" Ford rears..
I recently bought a set of 9" FACTORY ford gears from B-Man. I questioned him about whether he actually was selling a true Ford made gear set. (HE WAS). I bought the gears.
The vast majority of the gear manufacturers do not hold the same standards for noise, strength, wear, etc as an OEM (Ford, GM, etc).
The fact that you had a 9" rear under a GM 3rd generation Camaro says a lot, LOL!
A Quote by Jimmy Keen when GM "Super Street" racers complained about him using a 2 speed Powerglide trans in his Mustang: " I will run a Ford transmission IF you put the 10 & 12 bolt GM rears back into your cars." END OF DISCUSSION.
Tom Vaught
ps The TOPIC was about QUIET GEARS and Ford does a great JOB with quiet gears in many cases.
Old 07-16-2010, 06:25 PM
70 bird's Avatar
70 bird 70 bird is offline
You need to pull it apart and have a look, they might be setup wrong. Ive used summit, richmond, and motive brand gears and they all were quiet.
Old 07-16-2010, 06:40 PM
Tom Vaught's Avatar
Boost Engineer
You aint making the power to make them noisy! (:>)
When we going to lunch again???????
Tom Vaught
Old 07-16-2010, 07:16 PM
gears."
Tom Vaught
You are right as i did read what you posted wrong.....and one of these days i'll win a "conversation" with one of you two....lol.....but until then..... My daddy worked for Ford and my Buddy had the Ford rear in his 3rd gen so that says alot about them.... I sir like Pontiacs so that speaks volumes about me.......lol
My buddy's rear had other "issues" besides the gear set and once corrected was as quiet as a church mouse with the gears it was supplied with. I will stand by my original post as there are alot of "issues" i have heard of with rearends reagardless of make from certain compaines........
Old 07-16-2010, 11:01 PM
455firebird1969's Avatar
X2 Who installed the gearset? I would pull the cover to make sure the tooth contact pattern and backlash are correct (shimmed properly)...
I've had good luck with Richmond gears, very quite...
I just put a set of Motive gears in, they seem like good gears, I can't hear them but its a open header car...
Old 07-16-2010, 11:06 PM
67 Lamnas's Avatar
Moser........
I'm thinking I'm just gonna find an OEM gearset and do it myself.......
No one is going to take more care than I will......
Will do it after I get back from the Indian Uprising......
Thanks for the responses
"XE cam basher"
Old 07-16-2010, 11:08 PM
67 Lamnas's Avatar
BTW, anyone have a link to a good price for Timken bearings?
"XE cam basher"
Old 07-17-2010, 11:55 AM
Tom Vaught's Avatar
Boost Engineer
Any price is a GOOD price for Timkin Bearings!
Tom Vaught
Old 07-17-2010, 05:03 PM
67 Lamnas's Avatar
$61 and change for four cups and cones to my door....not bad
"XE cam basher"
