Old 09-05-2010, 08:51 PM
S Courter's Avatar
S Courter S Courter is offline
Default Trunk support rod replacement
What does it take to replace the trunk lid support rods in a 71 Firebird? Mine must be broken because trunk lid won't stay up.
Steve
71 Pontiac GT-37 400 4 spd (sold)
71 Formula 400 turbo 400 (sold)
01 Firebird T/A WS6 auto (fun)
64 Tempest Post car LS1/4L60E (Love It!)
65 Lemans Post car LS1/4L60E (More Fun)(sold)
73 Lemans GT 400/auto 1 owner 52k miles
69 El Camino LS1/4L65E (Awesome)
70 Pontiac GTO Convertible 400/400 Original (sold)
69 Olds Cutlass S W31 Numbers matching 4Spd 3:91 one of 569
72 Post Coupe GTO 400/400 1 of 60 built 1 owner original
Old 09-05-2010, 09:35 PM
2manyT/A'S's Avatar
Pull your rear window trim to access the three screws underneath that hold the filler panel on.
The other three are accessable when trunk is open.
Remove trunk lid & (rear window glass) to be safe.
Cars with rear spoilers have a fatter rod.
Be carefull as those torsion bars have ALOT of SNAP to them.
A couple of pry bars & friends make the job easier & SAFER.
Old 09-05-2010, 10:05 PM
lniemeyer2's Avatar
lniemeyer2 lniemeyer2 is offline
X2 on what 2many said.
I would definately remove the rear glass or one slip and it will be history. I had mine slip a few times before I got it in place and was very glad I had took the time to remove it.
1974 Formula 455
Old 09-05-2010, 11:49 PM
x-bird2 x-bird2 is offline
before removing what you have, check to see if there is still an adjustment slot left to move the rod end into. And yes, even after three decades, those rods still have a lot of snap to them. I use a 3/8 or 7/16 deep socket on a ratchet to release or move them. Slip it over the bar end with the ratchet handle vertical and move it to where it needs to go. Always did it with the glass in, just put a wool blanket folded up several times on the glass as a backup.
Old 09-06-2010, 05:22 PM
beltrunner beltrunner is offline
Just to share my recent experience with these trunk rods...recently replaced them on my '71 Formula with spoiler. Ordered them from Classic Industries. 3 times they sent me the wrong one for the RH side (Heavy Duty one). I finally got the correct one and installed them (didn't remove glass, but padded the heck out of it). The new rods worked great for about a month. Then the trunk started to close by itself again ( on stiffest adjustment notch). So now I'm back to using a broomstick. Good thing I seldom open the trunk, as the fewer things in life that raise my blood pressure at my age the better...
Old 09-06-2010, 07:01 PM
2manyT/A'S's Avatar
That's SO typical of alot of reproduction parts. (they look great,but don't work well/last for very long)
I'll go out of my way to hunt down good ORIGINALS.
