Old 11-21-2010, 12:28 AM
lmf01 lmf01 is offline
Default Bolt Removal - Wilwood Hub
Ok all need to see if I am missing something here. Pic attached By The Way. This is a Wildwood HUB from a 67 Firebird. I am in the middle of brake and suspension rebuild. The Star Drive bolt in the picture simply will not come out. I have tried everything. Impact Wrench, large wrench with a with a huge breaker bar, everything. Tried reverse thread, everything.
There are 8 or so of these and non of them have even budged.
Any Advise????
Old 11-21-2010, 12:58 AM
andyleonard's Avatar
andyleonard andyleonard is offline
Maybe call Wilwood and ask them what they're glued with? Maybe heat? If you've tried the old-school hand-held impact driver that you beat on while it twists...I don't know.
Old 11-21-2010, 01:53 AM
Perhaps some green Loctite 640 high heat retaining compound was used to assemble them. You may need to carefully apply some heat with a torch for removal.
Old 11-22-2010, 08:51 AM
HWYSTR455's Avatar
Why would you want to take it apart? If you need a rotor, send the whole thing to Wilwood for service. They are fairly inexpensive, have quick turn-arounds, and you'll be sure you don't have the thing come apart on you when you don't want it to.
And those are called torx screws, fyi.
