Old 12-10-2010, 09:25 PM
klunker klunker is offline
Default 66 Lemans, 4 speed, console, gages, posi
I bought this 1966 Lemans with the intention of parting it out. But after taking a good look at it I think its almost too good to part out. It has been sitting in a barn for since 1973. It was parked due to a leaking water pump. It is a nicely optioned car. Options include 4 speed, console, rally gages, 3.36 posi., padded dash (no holes in dash pad) Manual steering and manual brakes. Engine is a 326 with a 2 barrel carb.
There are some small rust spots, both front fenders have a hole in the bottom rear corner, the passengers side dor has a small hole in the lower front corner, there is a small hole around the rear window on the passengers side, rust seems to be starting to break thru on the drivers side of the trunk lid. The trunk has rust breaking thru above both of the frame mounts on the front edge of the floor of the trunk. Other than these spots the floor boards have no holes. The engine turns over, I have not tried to start it. I had to cut the drivers side rear brake drum to get the car to roll as that drum was frozen. The car is now stored inside in a garage. This would be a nice car to go thru mechanically and then just drive it daily. Or if you have a rough GTO that needs alot for restoration here is a good parts car.
I will sell for $4200. email me at [email protected].
Name:	66 for ebay 010.jpg
ID:	227628   Click image for larger version
Name:	66 for ebay 039.jpg
Old 12-10-2010, 09:32 PM
more pictures
Name:	66 for ebay 015.jpg
ID:	227631   Click image for larger version
Name:	66 for ebay 037.jpg
Old 12-10-2010, 09:39 PM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
if it doesnt sell as a whole and you part it out, let me know, id be interested in the complete dash gauges and pad
Old 12-11-2010, 12:24 PM
make me a good offer on the parts you want, if its attractive enough the parting will begin!!
Old 12-13-2010, 11:44 PM
RustyNutz&Rodz's Avatar
RustyNutz&Rodz RustyNutz&Rodz is offline
Email sent on the car....thank you!
Rusty Nutz & Rodz
www.RustyNutzRodz.com
1967 GTO 400 Auto
1967 GTO 400 HO 4-Speed
1966 GTO 389 3x2 4-speed Tiger Gold
