Old 01-26-2011, 04:16 PM
Midnight Goat's Avatar
Midnight Goat Midnight Goat is offline
Default Would this Chevelle brake kit work with my 67 GTO?
http://www.ss396.com/chevelle_parts/..._brake_kit.htm
Seems very close in price to sourcing the conversion parts separately. My master is bad anyway so its almost identical in price. Also comes with upgraded rotors for no extra cost. Am I missing anything in this kit to do the conversion? Im sticking with my rear drums, does that effect anything?
1967 GTO- 400ci of PONTIAC iron, 4bbl 770 cfm holley,670 heads, headers, 4spd, and a busted fender.
2005 GTO- 400hp of corporate ls2, lingenfelter intake, Corsa sport exhaust, reprogrammed tcm, Boyd Coddington Smootie II's, and a crap load of zaino!
Old 01-26-2011, 06:23 PM
Couldn't find the edit button,
Do you need to modify the brake lines in any way to do the conversion? I need a new master/booster and prop valve. This kit should work but I want to make sure I'm not missing something.
Old 01-26-2011, 09:04 PM
buds56's Avatar
buds56 buds56 is offline
Make sure you get the 9" booster, the 11" hits the valve cover and inner fender.
I found this out the hard way on my 64.
Old 01-29-2011, 01:49 PM
Big Injun's Avatar
Big Injun Big Injun is offline
Looks like a good kit. You will need to re-use your steering arms off of your stock drum spindles. make certain to get the Delco Moraine stamped 9" booster.
Dave "Big Injun" Anderson
[email protected]
www.4mypontiac.com
For GTO Celebration items click the tile coaster.
Old 01-31-2011, 11:08 PM
HaloMedic's Avatar
HaloMedic HaloMedic is offline
would this also fit a 66 gto i know that there were changes between 66 and 67
I would also would want to know weather that spindle is stock heighth and not dropped 1 to 2 in ive seen some other kits that were no the stock heighth
Gentlemen put your trust in God, But mind to keep your Powder dry. Oliver Cromwell
Michael Hughes Sr
1966 GTO Convertable: Stolen never recovered
1966 GTO Hard Top .30 over 455 4-Speed 3:23 Posi
Old 02-01-2011, 01:00 AM
Big Injun's Avatar
Most of these kits fit all '64-72 A-bodies. More importantly, you should be asking these questions directly to the vendor.
[email protected]
www.4mypontiac.com
Old 02-01-2011, 05:32 AM
ron cozzo's Avatar
ron cozzo ron cozzo is offline
The 11" booster would be correct for your '67 GTO. Use the 9" if you have taller aftermarket valve covers.
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc.
'02 Firebird, V6, auto
'68 GTO Convertible, HO, 4spd, driver
'66 LeMans Hardtop, 400, FI, A/C, 4L80E.
'65 GTO Hardtop, restoration ongoing
'64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue.
http://www.gtoaco.com
Old 02-01-2011, 08:38 AM
HaloMedic's Avatar
Sure that works, most dont, thats why i was asking here, but i guess its worth a try
Michael Hughes Sr
Old 02-05-2011, 11:14 AM
1967SC's Avatar
1967SC 1967SC is offline
What about the bolt pattern on the rotors ?
