Old 01-30-2011, 04:17 PM
slowbird's Avatar
slowbird slowbird is offline
Default 2nd Firebird fuel tank weight?
Anyone have know what a stock fuel tank weighs in a 2nd gen Firebird?
Old 01-30-2011, 05:10 PM
MotorHead_811 MotorHead_811 is offline
Im gonna guess around 15 - 20 pounds mine didnt seem to heavy when I took it out
78 firebird 400/t400
Old 01-30-2011, 05:52 PM
dda72's Avatar
dda72 dda72 is offline
31 lbs. including the holding straps.
Old 01-30-2011, 06:10 PM
slowbird's Avatar
Really!!!
Old 01-30-2011, 06:11 PM
slowbird's Avatar
Ok so does anyone know what a 5 gallon fuel cell weighs?
Old 01-30-2011, 06:36 PM
dda72's Avatar
Originally Posted by slowbird View Post
Really!!!
For you I went and weighed the one that came out of my car using the house scales. My wife was not too happy!
Old 01-30-2011, 06:38 PM
slowbird's Avatar
LOL, Thanks I am now looking at things that I didn't want to do but I need to get some weight out of the car. So I think the stock tank is going and cell is going in.
Old 01-30-2011, 06:41 PM
dda72's Avatar
4.5 lbs. empty of course.
Old 01-30-2011, 06:52 PM
slowbird's Avatar
Plastic or alum?
Old 01-30-2011, 06:58 PM
dda72's Avatar
Plastic. Purchased new in 1994 and still like new. The 4.5 lb. weight included vent and metal straps used to mount inside the trunk.
Old 01-30-2011, 07:11 PM
David Holmberg's Avatar
It's weight, but it's good weight. Low and centered between the rear tires...
The help will be less fuel needed to cover the sump.
Old 01-30-2011, 08:16 PM
1qikta's Avatar
1qikta 1qikta is offline
You can get a 7 1/2 gallon cell in it...With some work
Name:	fuel cell 4.jpg
ID:	232835   Click image for larger version
Nothing is impossible if you break it down into possibilities. It's all a matter of "Want to".
Old 01-31-2011, 12:15 AM
Johnny406's Avatar
Johnny406 Johnny406 is offline
I took mine out back in 93, if I had to do it over again I don't think I do it.
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
Old 01-31-2011, 10:30 AM
PONTIAC DUDE's Avatar
Thumbs up
My stock Tank is cut on each end just past where the straps hold it in. Then flat steel welded in place. Holds about 9 gallons. I run 3/5. Still has the stock sending unit with the rear AN sump. I use the stock 3/8" top line for the return form my 500 gph pump.
Old 01-31-2011, 12:38 PM
BTW gasoline weighs roughly 6 lbs per gallon. Aluminum Hard line vs braided saves some weight too.
Old 01-31-2011, 12:54 PM
60man's Avatar
60man 60man is offline
At your performance level I would have had one in a long time ago......safety. IMO
I vented mine outside with a RO valve. Don't for get to figure in mandated rear firewall.
I run 5/8 ID push loc hose. Protected where necessary.FWIW: I think aluminum hard line is rated in OD....
ECM member.
MANDRA
