Old 01-31-2011, 10:07 PM
t/a 79 t/a 79 is offline
Default new springs
I installed my new springs controle arms and rims/tires this weekend
ID:	232982   Click image for larger version
Old 02-01-2011, 08:57 AM
amcmike's Avatar
amcmike amcmike is offline
Very nice. Looks a tad high in the back, but if you're changed the rear leafs it should drop a little over time.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 02-01-2011, 09:07 AM
I agree the rear looks a little high hopefully it will drop a a bit but the tires i went with are short they are nitto nto5 275 40 17 allthe way around on the positive side no more weal hop ( also put on comp eng. tracktion bars ) hangs on in corners like it is on tracks
Old 02-01-2011, 09:36 AM
Charlie Brengun's Avatar
Charlie Brengun Charlie Brengun is offline
When the car drops a little it will look really good. nice car btw
1968 - Pontiac GTO
Old 02-01-2011, 10:51 AM
amcmike's Avatar
Yeah, on a 2nd Gen I would have gone with 18s (they're closer to stock height). Maybe when you wear them out, you can upgrade to 285s. Might not fit the front, but if the backspacing is correct they should fit the rear.
Old 02-01-2011, 06:00 PM
There is plenty of room inthe rear but i liked the nto5 dont think they made a 285 in the 17" with the extra room i have I may try the 315 35 17 same hight but 2" wider
Old 02-01-2011, 06:18 PM
aronhk_md aronhk_md is offline
How are ya gonna get 315's on those 9" wide year one rims? If I remember right the 315 tires are about 11" from bead to bead, and I think the recommended minimum wheel width is 10".
Old 02-01-2011, 07:21 PM
well then i guess i may have to get diferent rims if I decide on the 315 /35/17 will i not
