Old 02-10-2011, 11:27 AM
68lemansman's Avatar
68lemansman 68lemansman is offline
Default Heater not working!
Ive got a non a/c car. I was running the car for a good 45 min and had the heater on and turned to hot. The car stays at a normal temperature.Ive got good amount of air coming out but its not hot or even close to being warm. Any ideas what could be wrong? Thanks Jason
Jason
1968 lemans :In progress!
1970 Bonneville 455 HO convertible (survivor)sold
1969 firebird
Old 02-10-2011, 12:22 PM
2002Z4CSS's Avatar
Thermostat stuck open. Grab the heater hoses and see if they are both hot to the touch. If one is hot and the other cool, the heater core may be plugged. Check coolant level.
1971 Pontiac GT-37
Old 02-10-2011, 12:29 PM
goatnut's Avatar
goatnut goatnut is offline
You say the car is at normal operating temp so I would check the blend door and see if it is opening and closing properly. You can move the temp lever quickly and listen for the door to slam. Also check the heater core for blockage feel the heater hoses the inlet hose should be hot and the outlet hose warm. If car is heating up to normal operating temp in a timely manner and gauge reads normal I doubt a thermostat.
69 GTO Judge
69 Firebird Trans Am clone
76 Trans Am 400 4spd.
06 GTO M6 18's red/red - 1 OF 188.
09.5 G8 GT Stryker blue met. premium with sport pkg.
Old 02-10-2011, 01:17 PM
thepontiacman's Avatar
I just had one that the heater core was stopped up. I replaced it and heater runs me out of there now.
Old 02-10-2011, 01:22 PM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
i'm leaning towards this as well.....stuck open T-stat.
how do you know the car is at normal temps? do you have a gauge?
same thing happened to one of mine a long time ago......barely any warmth from heater on full hot....stuck T-stat.
actually, it happened to my regular car couple years ago, only it had a gauge, and i could see it was low on temps with no heat coming from the vents.
costs too much
Old 02-11-2011, 08:27 AM
2002Z4CSS's Avatar
If you don't have a temp gauge in the car, just looking at the coolant with the cap off and when you just start seeing a bit of steam vapor, it is getting warm. You could put a thermometer in the radiator neck to check the coolant temp. If you have a 195 degree thermostat and the vehicle is at normal operating temp, you won't be able to hold on to the upper radiator hose for very long. When a thermostat sticks open, you will see coolant flow in the radiator with a cold engine. Normally you will see flow as soon as the thermostat opens.
1971 Pontiac GT-37
