Old 02-15-2011, 04:47 PM
car guy car guy is offline
Default Need help with turn signal dimmer lever removal
I have a 79 with tilt colum and of course the turn signal lever has the cruise and dimmer switch all in one. The manual says to simply pull the lever straight out. No way it is comming out, I have pulled until I am afraid I might break something and it wont budge. Can anyone give me some help? Thanks
2015 Challenger SXT Plus
2013 Charger RT/RT Super Trac Pac
86 Grand Prix LE
79 Anniversary Trans Am
Old 02-16-2011, 07:37 AM
JP_79Formula's Avatar
JP_79Formula JP_79Formula is offline
I have a 79 Formula, no cruise control... the lever has a detent lock that
rotates into locked position inside the turn signal/dimmer switch.
here's a link/photo of the lever ends posted by Ollie:
http://forums.maxperformanceinc.com/...1&d=1280843947
from a thread where several members here helped me go through the process...
http://forums.maxperformanceinc.com/...=640673&page=3
basically, it should be: twist to unlock the detent, then pull out...
Old 02-16-2011, 10:56 AM
Thanks I was able to get it by pulling as hard as I could and while pulling twisting it. I had tried to turn and then pull but that wouldn't work it had to be under pressure and twisted.
86 Grand Prix LE
Old 02-16-2011, 09:17 PM
Ollie's Avatar
Ollie Ollie is offline
That is good to know. But doesn't help when the tip is broken off flush with the canceling cam inside the steering column.
Its ok to giggle and snicker, Dont laugh and point
Old 02-18-2011, 12:30 AM
GStage1's Avatar
GStage1 GStage1 is offline
If you take apart the column and remove the upper collar/housing...you can knock out the lever with a center punch.
If you break the mechanism.....you can get that from any other GM car from 78-83...so don't worry about breaking it.....very easy to swap out.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
