Old 03-10-2011, 01:01 AM
winstonbike winstonbike is offline
Default Optons for brighter headlights?
1969 LeMans - what is the best option for a brighter headlight. This one is going to be my "daily" driver. Thanks
Mike
Old 03-10-2011, 10:34 AM
goatman-68's Avatar
goatman-68 goatman-68 is offline
Default Relay kit
Some people have used relay's to give the headlamps full voltage. Here is one example of a place that sells kits. You could save money by making your own setup but, (Mad) gives you a manual with there kit................
http://www.madelectrical.com/catalog/rly-1.shtml
Frame off (resto mod) 68 GTO - 406, 0-deck, E-Head home port 87cc, TRW L2279F30, Comp. flat solid .577/.577 - 248/[email protected] 110LS. 700R4, Precision Industries 3 disc 10" lockup 3500rpm, Moser 9" 4.11, Detroit Locker.
Old 03-10-2011, 03:40 PM
antique69lemans antique69lemans is offline
If you have not stepped up to a halogen bulb, there is a noticable improvement there. Proper headlight aim also makes a difference in usable field of view.
Old 03-10-2011, 04:18 PM
codyyy's Avatar
codyyy codyyy is offline
I think halogens would be the best bang for the buck. I'm almost debating putting some projector beams in my car, but that is a project best suited when the car is done.
Old 03-10-2011, 04:32 PM
David Jones's Avatar
I have halogens in my 69. It was a MAJOR improvement.
Old 03-13-2011, 07:26 PM
Half-Inch Stud's Avatar
Run the headlamp ground wires back to the Alternator case.
Old 03-13-2011, 09:15 PM
paint guy paint guy is offline
I'm running halogens and relays.
Old 03-14-2011, 02:14 PM
Just having new bulbs makes a big difference, light bulbs lose brightness every year of their life
Old 03-16-2011, 08:01 AM
lnorczen lnorczen is offline
I'm using Halogen Headlamps in my '69 and it does make a big difference over
the original ones. Good headlight aiming is a must as well.
- '69 GTO RAIII 4 speed H/T
- '09 G8 V6
