Old 04-07-2011, 04:04 PM
1stGen Brawler's Avatar
1stGen Brawler 1stGen Brawler is offline
Default Sticker shock!!!!
Went to our Chevy dealership yesterday to get a bottle of EOS. Don't ask why, that is not the point of the story.
Guy behind the counter printed the invoice and handed it to me. I stared at him like he had lobsters coming out of his ears.
Total - $26.32
One bottle. Just one. And yes, that bottle is still sitting at the dealership.
I had no idea.
69 Bird w/1970 400 block(409 cubes) and #64 heads, Dude spec'd hyd. roller, Q-Jet, full original interior, ps, th350, and 3.73 gears. Pump gas, d.o.t. tire, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118+ so far, but always looking for a little more.....
Old 04-07-2011, 04:33 PM
russosborne's Avatar
russosborne russosborne is offline
OK, I'll bite.
What is EOS?
Thanks,
Russ
Old 04-07-2011, 04:40 PM
one70gt37's Avatar
one70gt37 one70gt37 is offline
It's Engine Oil Supplement, 'E.O.S' has zzdp 'zink' in it for flat tappet cams,,they over charged you,, 16.95+ tax at my dealer.
In Paldiumn silver
'70 Tempest GT-37
'68 428 cu.in.
M-21 4 spd.
3.73 12 bolt
Old 04-07-2011, 04:41 PM
rohrt rohrt is offline
I did the same thing last summer. I couldn't find it anywhere. I think I paid the same.
Old 04-07-2011, 04:47 PM
68bird400HO's Avatar
68bird400HO 68bird400HO is online now
I think the aftermarket ZDDP Plus additive is cheaper. Also, it may be less expensive to just use and oil like Brad Penn Racing Oil that has the zinc in it, if you have it available to you. Check with your local machine shops or engine builders.
Old 04-07-2011, 04:52 PM
one70gt37's Avatar
Same here now, 1/2 bottle for 1 oil change is plenty. GM now has it under a different part number & revised formula i think, dealers can get stupid money for it.
In Paldiumn silver
'70 Tempest GT-37
'68 428 cu.in.
M-21 4 spd.
3.73 12 bolt
Old 04-07-2011, 05:20 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
yes its the price i had to pay when i did my cam swap last summer.
Had to pay since I wanted to do breakin later that day.
26 dollars is alot but the cam is healthy!!!
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
Old 04-07-2011, 05:29 PM
Yeah, I hear ya on the race oil. I was limited due to time and some other factors or I would have.
I hadn't bought the stuff in a while but I swear last time I got some it was around $10. For $26 I thought the guy would drive over and pour it in for me!
Old 04-08-2011, 12:28 AM
SRR's Avatar
SRR SRR is offline
Vavoline VR1 has ZDDP in it.
― Calvin Coolidge
Old 04-08-2011, 12:39 AM
mikeb mikeb is offline
STP has zddp in it also. I've broken in two cams with it recently with no issues whatsoever. It really helps to remove the inner valvespring when you are breaking in a cam.
Old 04-08-2011, 01:01 AM
screamingchief's Avatar
screamingchief screamingchief is offline
Might wanna look into Torco ZEP,it's like $13.95 per bottle direct from Torco,and it can probably be had just a bit cheaper than that thru a distributor or such if you have one that's local to you.
I know Ace @ PPR sells Torco oils & products,so he might have it for less too.
Torco ZEP Link.
Torco makes good oil & lubricants!
HTH
Bret P.
This space for rent...
In the meantime,check out the cars HERE.
Old 04-08-2011, 11:34 AM
Derding's Avatar
Derding Derding is offline
I picked up some of this stuff at Advanced Auto the other day. I think I paid $7.99
http://www.barsproducts.com/4401.htm
Old 04-08-2011, 08:30 PM
Elarson's Avatar
Elarson Elarson is offline
x2 Make sure you get the stuff labelled "not street legal"
Eric
Old 04-08-2011, 08:39 PM
I also use STP no problems. $4.00 a bottle.
Old 04-08-2011, 10:05 PM
abefromen's Avatar
abefromen abefromen is offline
.X3
