Old 04-10-2011, 11:42 AM
HaloMedic's Avatar
HaloMedic HaloMedic is offline
Default Mr. Carburator Plumber Needed
Iam so done with this as i pull my hair out. not knowing what size or what NPT stands for, my problem is with the fittings that i need. so at this point i call it mission impossible ( for me ) Here is a list of the components that im trying to plumb together
QTF 4150 Based SS-750 Duel pumper carb
http://www.quickfueltechnology.com/c...50-cfm-ms.html
QTF SS duel fuel line
http://www.quickfueltechnology.com/s...an-silver.html
into
6" to 8" of braided fuel line
into
Edelbrock Hi-Perf Reg.
http://www.summitracing.com/parts/EDL-8190/
into
4" to 6" of braided fuel line
into
Edelbrock fuel filter
http://www.summitracing.com/parts/EDL-8130/?rtype=10
into
19.5" Braided fuel line
into
Mr Gasket Hi-vol 4.5 tp 9 psi Mech. Fuel pump
http://www.summitracing.com/parts/MRG-7710/
( ) insert your name here if you choose to accept this mission you will be rewarded with the purchase of the beverage of your choice.with a few exceptions no
http://www.bevmo.com/Shop/ProductDet...ProductID=1587
http://www.aabalat.com/stores/item.c...D/1286603.html
Ok The budget for the beverage is $ 20.00
Gentlemen put your trust in God, But mind to keep your Powder dry. Oliver Cromwell
Michael Hughes Sr
1966 GTO Convertable: Stolen never recovered
1966 GTO Hard Top .30 over 455 4-Speed 3:23 Posi
Old 04-10-2011, 11:51 AM
track73 track73 is offline
The "Google" is your friend.
Old 04-10-2011, 11:57 AM
limejudge69's Avatar
NPT=National Pipe Thread
Old 04-10-2011, 12:02 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
NPT as said is pipe threads. Most reulators and race pumps use either 3/8 or 1/2, the street pump you have listed uses 1/4".
So you will need a 1/4" NPT male to -6 adapter to go to the hose to the regulator. -6 ends on the hose to the regulator. Two 3/8 male NPT to -6 fitting for the inlet and outlet of the regulator. Female -6 ends to hook all the hoses up they come in different anlges depending how you want to route the hose.
You will need a 1/4 NPT to 3/8 fuel line hose to hook the pump to the chassis fuel line.
Skip Fix
Old 04-10-2011, 12:12 PM
Tom Vaught's Avatar
Boost Engineer
NPT=National Pipe Thread is a TAPERED THREAD 1/8" pipe, 1/4" pipe, 3/8" pipe, 1/2" pipe, etc. The taper rate for all NPT threads is 1⁄16 (¾ inch per foot) measured by the change of diameter (of the pipe thread) over distance. The taper divided by a center line yields an angle 1° 47' 24" or 1.7899° as measured from the center axis. Commonly-used sizes are ⅛, ¼, ⅜, ½, ¾, 1, 1¼, 1½, and 2 inch, appearing on pipes and fittings by most U.S. suppliers. Smaller sizes than ⅛ are occasionally used for compressed air.
Most older Fuel Pump regulators and fuel pumps were a NPT thread.
Newer Fuel Pumps and Regulators can have a "Straight A/N thread".
The AN thread is a particular type of fitting used to connect flexible hoses and rigid metal tubing that carry fluid. It is a US military-derived specification stemming from a joint standard agreed upon by the Army and Navy, hence AN. The standard is sometimes mistakenly referred to as "Air Force-Navy", but it dates back to World War Two, before there was a separate US Air Force.
AN sizes range from -2 (dash two) to -32 in irregular steps, with each step equating to the OD (outside diameter) of the tubing in 1/16" increments. Therefore, a -8 AN size would be equal to 1/2" OD tube (8 x 1/16 = 1/2). However, this system does not specify the ID (inside diameter) of the tubing because the tube wall can vary in thickness. Each AN size also uses its own standard thread size.
(THE DEAL IS THAT A -8 A/N LINE DOES NOT TRULY HAVE A .500" INSIDE DIAMETER. MORE LIKE .437" INSIDE DIAMETER.) the statement above is close but not accurate if you are calculating actual fuel flow capability. Same deal when doing oil lines for coolers, remote filters, etc. If the hole in the block is a drilled 1/2" hole go one size bigger on the A/N hoses.
The Aeromotive web site is a very good source of info on fuel lines:
http://aeromotiveinc.com/2010/01/an-vs-npt/
Tom Vaught
The Following User Says Thank You to Tom Vaught For This Useful Post:
Old 04-10-2011, 12:28 PM
ta man ta man is offline
When I was plumbing my fuel system ..I drew a picture from the tank to the carb to make sure I didn't miss anything.All your parts list what the inlets and outlets are..you just need the proper fittings.
Old 04-10-2011, 02:09 PM
67cruiser 67cruiser is offline
THESE GUYS SAID IT PERFECT, Its really quit simple.I talked to Cliff rurglles as much as possible. He really helped me because of a street strip car. Pushed the no.8 stuff to me, never a regret. Car is a blast to run. All depands whats your doing with the car. I put in a No.8 fitting even in the fuel inlet nut. Everything was a breeze. Except for a glogged fuel filter that i never caught. Enjoy the ride! Rich P.s. remember one thing, best lesson i learned, upon acc. all fuel heads back towards the fuel inlet tube so put in a drop tank and go get em.!!
Old 04-10-2011, 07:39 PM
HaloMedic's Avatar
Thanks to all who have chimed in here Skip Fix has given me a new prespective on the whole deal
NPT as said is pipe threads. Most regulators and race pumps use either 3/8 or 1/2, the street pump you have listed uses 1/4".
has me stumpt tho the thread diameter is larger then a 1/4"
need a caliper
Michael Hughes Sr
Old 04-10-2011, 08:22 PM
WDCreech's Avatar
WDCreech WDCreech is offline
The pipe thread measurements are for pipe size that would be used.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 04-10-2011, 09:42 PM
stimpy stimpy is offline
On a NPT fitting the size is the ID of the fitting not the exterior so the bore will be 1/4 " on a 1/4" npt fitting and the leading edge of the threads are around 3/8 in Outside diameter , on fluid carriers the size is suposed to be the interior bore measurement not the exterior size
Old 04-10-2011, 10:41 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Also remember, as Tom stated, NPT threads are tapered. So, don`t go hog wild on tightening as the fitting gets "bigger" the more you tighten. You can split the bore if you are careless.
Old 04-11-2011, 12:41 PM
Skip Fix's Avatar
"Also remember, as Tom stated, NPT threads are tapered. So, don`t go hog wild on tightening as the fitting gets "bigger" the more you tighten. You can split the bore if you are careless."
And if you are tapping a hole make sure you don't go bigger than the actual fitting to seal!
Skip Fix
Old 04-11-2011, 06:31 PM
HaloMedic's Avatar
Thanks Guys I ordered the parts this morning im confident that I ordered are right, Skip Fix Id like to buy you that drink now you were the first to point me in the direction i needed to go . Dont understand why i didnt see it that way when i started.
Michael Hughes Sr
