61 Wing Window Weather Seal
to replace the weather seals inside the wing window....
it's 2 piece, and it looks like leading edge seal (that wraps around the lower curve, has a hole that the pivoting post goes through. and it looks like the only way the pivot post can come out, is if the glass comes out of the glued-in channel.
is this right? only way to put in seal is to remove the pivoting wing window, and the only way to remove pivoting wing window is to pull the glass out of glued in channel?
_____________________________________
www.malunacoolers.com
