Old 05-04-2011, 01:28 PM
8LUG 8LUG is offline
Default 63/64 Tach
Finally finished installing a new lens on my tach, not for the faint of heart. repainted the pointer, came out good!
ID:	243376   Click image for larger version
Old 05-04-2011, 01:52 PM
Deadhead's Avatar
Deadhead Deadhead is offline
Nice!
Congrats on that. I have had a '66 apart. I know what you mean.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 05-04-2011, 03:45 PM
Ziggy Ziggy is offline
Good looking '63 tach!!
Old 05-04-2011, 06:16 PM
Default 63/64 TACH
1963-64 exe. T.I. HEAD ASM,tachometer 6411451, 1963-64 P/8 w/T.I. HEAD ASM,tachometer 6411585 Same part number Also picture from 1964 dealer album. 1962 had the cone knob and straight printing on tach face
Old 05-04-2011, 06:18 PM
Default 63/64 TACH
Forgot the picture!
Old 05-04-2011, 07:11 PM
Something is strange here... Is yours a TI or std I tach?
I saw the picture out of the manual you posted.
I always thought the distinguishing things between the '63 and '64 tach was that the '63 "RPM/Hundreds" was curved and the '64 "RPM/Hundreds" was straight. But, I assumed this for the standard ignition tachs. I am not sure about the 'TI tachs.
I have a '64 dated(stamped in back) tach with a straight "RPM/Hundreds" on the face. It has the correct knob (for '63 and '64" ). But, you say the '62 tachs had "straight lettering". Did someone change the internal face plate on my '64 "back in the day" to a '62? I am curious?
Anybody else have a '64 with a straight lettering of "RPM/Hundreds" on the face?? Please chime in......
Old 05-04-2011, 09:39 PM
Engine-Ear's Avatar
How did you get the bezel ring off without breaking the little tabs that hold it on?
Followup tech question: if you (or I, in this case) DO break off those tabs, will clear silicone (or ???) hold it on OK?
Please carify what you mean about the curved vs straight printing...you mean "RPM" and "HUNDREDS", right? I assume that the numerals are all laid out on a curve.
RediRad circuit designs, branding and intellectual property are for sale.
Serious inquiries only.
Old 05-04-2011, 10:48 PM
Matt ,tape the end of the bezel, then use a 5" hose clamp to install it right on the edge of the bezel by the tabs. Gentley bend the tabs a little at a time, the hose clamp will also keep the bezel from distorting. Dont think silicone would work because a rubber washer is in between and the tabs hold a little pressure.The RPM & HUNDREDS are arched on the face of the 63/64 tach.
Deadhead's Avatar
Yeah ? X2 BTDT
-LBJ
66 Bonneville wagon
2005 GMC L-33
Old 05-06-2011, 10:54 AM
MPKind's Avatar
MPKind MPKind is offline
My 65-66 tach needed the needle and lens fixed, so I recently took it apart. What a mess it was. It had been repaired once, and the redline needle had a screw tapped into it. It didn't rotate without moving the glass. I got it to look and work better than before, but still not happy. I'm sending it out to APT in Bloomington, MN before I break something and really muck it up.
Old 05-06-2011, 01:35 PM
Stuart's Avatar
Stuart Stuart is offline
They do good work. I had them fix the Pontiac tach I installed in my car (since my car is a 1961 they didn't have a factory tach that year so I used a newer one, although I don't recall what year it is exactly.) They've done some motorcycle speedos for me as well.
