Even since I bought my Catalina in 1998, it's had this annoying speedometer "rattle."
It only makes the noise when the car is moving, and it is a mechanical rattle in the speedometer mechanism. It changes "pitch" at increased speed. I've taken the cable off and shot some white grease down it. That didn't change it at all. I figure it's probably a bushing, or bearing that needs some lube. Before I tear the dash apart, is there anyway to open the Speedometer itself to access the components? Thanks, MK |
Yes, there was dis-assembly provisions back then, but I would try a new cable first.
Might make a difference. Easier that changing out the whole speedo head anyway ![]() Ian ![]()
To laugh at men of sense is the privilege of fools. |
You can but you don't have to. You can get either take off the pad or lie under there to unscrew it. I think you might be able to take the speedo out with the pad off if you had to.
"If you do everything you'll win" -LBJ 13 Smiles per Gallon: 66 Bonneville wagon 66 Bonneville 2d HT - In perpetual progress 2005 GMC L-33 |
I took it all apart, and got the cable out. It was really clean, but I cleaned it and lubed it up. I had a heck of a time getting it back in, I haven't taken it for a test yet, since it is raining out now..
MK |
Couldn't wait. Took it out in the rain. GASP! (First time driven in the rain since 1999.)
No more rattle. Once again, PY forums worth a mint. Thanks, MK |
