Old 05-15-2011, 07:12 PM
kob153's Avatar
kob153 kob153 is offline
Default hello engine help please
can any one tell me how do i find out what car my engine cam out of ..and is it a 350 or 400..it says 350 stamped on the side.. and right by distrib it has a 75 stamped in it ..but the guy i got it from says it a 400. can any one tell me how do i find these things out about this engine thanks
ID:	244469   Click image for larger version
Old 05-15-2011, 07:23 PM
nashcar nashcar is offline
What are the numbers stamped on the block below the passenger side cylinder head?
69 Z 302 M21 3.73
http://www.byjanmarie.com/camaro/Z28.html
69 FB 400
http://www.byjanmarie.com/firebird/69.html
69 Camaro 327 4sp. 4.10
http://www.byjanmarie.com/camaro/69camaro.html ( SOLD)
2002 Camaro LE/SLP-(sold)
1967 Nova SS-- 327, M20, 3.73, FRT Disc
Old 05-15-2011, 07:33 PM
kob153's Avatar
the number on back of block 500810 and the number on front of block 112517 yb and the number by distrib is j207 75 stamped in it
Old 05-15-2011, 07:34 PM
kob153's Avatar
oh im sorry didnt no there is a numer stamped there gonna go check
Old 05-15-2011, 07:36 PM
limejudge69's Avatar
http://www.wallaceracing.com/enginesearch4.htm
Scroll down about halfway down. The engine code locations are there. To properly identify your engine, you will need the 2 letter code off the front and the date code on the back of the block near the distributor hole.
Old 05-15-2011, 07:39 PM
kob153's Avatar
its says 350 stamped on that side of block
Old 05-15-2011, 07:44 PM
kob153's Avatar
i put those codes in and nothing
Old 05-15-2011, 07:45 PM
YB is a 350. 500810 also confirms that it is a 350.
Old 05-15-2011, 07:49 PM
kob153's Avatar
Year Engine HP Engine code Trans CR Cam Head Code BBL Carb No. Misc
1975 350 155 HP YB A 7.6 555 5C 1-2 7045171 Block Casting # 488986
this is what it came up with thanks limejudge69 but how come i dont see these number on the block i see different numbers
Old 05-15-2011, 07:53 PM
kob153's Avatar
CAN I IT A 18X10 ON THE BACK OF A STOCK FIREBIRD
Old 05-15-2011, 08:51 PM
Cammer-6 Cammer-6 is offline
Yikes
translation please
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 05-15-2011, 10:52 PM
That is a strange one.
I'd say it's a 1977 350, by the date code, anyway. (Oct 20, 1977)
The 500810 block casting was a late 76 block casting for 350.
Probably ran into 1977 also.
Why it has a 75 by the distributor, I don't know.
Does it have only 3 engine mount holes on side of block?
Look on the front of the block, passenger side closer to the timing cover area, down low.
Should be a partial VIN - looks like this probably:
27N1xxxxx
Tell us what that says.
Old 05-16-2011, 11:27 AM
Actually, you may have mis-read the date code, probably J205?
It will still be a 350 engine though.
The 77 YB would have come in a GP or LeMans.
The 75 TB would have been in a Firebird, 2bbl though.
Old 05-16-2011, 09:40 PM
kob153's Avatar
112517yb is stamped on front right top of timing chain 26n522430 is stamped right next to timing cover for some reason i cant post pics on here i tookpics of it
Old 05-16-2011, 10:01 PM
The 112517 is the Engine Unit Number (or Motor Unit Number)
The YB is the engine code (needed for my search page)
The 26n522430 makes it a 1976 Pontiac Firebird.
(the 522430 is the last 6 digits of the VIN of the Firebird the engine came from)
That makes the date code J205, which was probably mis-read as I said.
So the block was cast on Oct 20, 1975 for the 1976 Model year.
Still a 350 unfortunately.
With that partial VIN (26n522430) you could send it to PHS and find out what the car was originally optioned with. (for a fee though)
