Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 06-14-2011, 07:36 PM
rodneybutler's Avatar
rodneybutler rodneybutler is offline
Default Rodney Butler's complete clutch and bellhousing
Hays 2 disk, aluminum hat and flywheel. New fingers, inserts, disks (5135), floater. Has one race on it since fresh (Norkwalk last year 6.27). Comes with 3 sets of springs, spare fingers, disks and floaters. Lots of shims, weights, etc. Same clutch Arnie runs in the Tameless Tiger and Bag Boys Grocery Getter. $700.
Lakewood steel 8 1/8 bellhousing. Liner, cross shaft, candlestick, and throwout bearing. Pontiac and Chevy pattern. $700
$1300 for both. This would cost you $5000 new! This combo will work well for a mid 6 to 8 sec car.
Also have an Autometer 34 channel data logger with drive shaft, vac sensor, accelerameter. $500
Call Rodney Butler 866-762-7527
Old 06-14-2011, 07:52 PM
INJUNTOM's Avatar
INJUNTOM INJUNTOM is offline
Nice to see you join up. Hopefully you'll have time to hang out a little...
Old 06-15-2011, 01:27 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Rodney,
Glad to see you on the PY board. Many if not all will value your input and contributions.
If you have time we all would like to hear a bit more about the last year of test and tunes for your record setting hot rod.
See you soon,
Jim
Old 06-16-2011, 02:04 PM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
agreed with the other fella's, glad to see someone from the Butler Crew join up! I was glad to work with you fellas on my stroker build. engine's running great!
good luck with the sale.
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 06-26-2011, 02:36 AM
riceslayer's Avatar
riceslayer riceslayer is offline
Sup Rodney
Old 07-03-2011, 07:26 PM
bump. good deal for someone
Old 07-05-2011, 09:14 AM
gkinch's Avatar
gkinch gkinch is offline
Will the bellhousing work with a small cased CS-3 Lenco Trans?
Gene Kinch
1969 firebird CVMS 468,t-400,9inch 3.50 rear 11.58@116
1979 TA 462,t-400 3.23 10 bolt 12.76 @ 108
1971 GTO 400,t400 3.23 10 bolt all original 14.41@96
1968 GTO Gallop-n-Goat race car CVMS 462,pg 4.56 12 bolt eheads 5.98 @115 on e85
1995 Jerry bickel ex-pro stock Firebird,sonny leonard 632,Glide,9 inch 4.10 rear 7.08 @198 ( crashed and under reconstuction)
1979 TA, 400/ 4 speed all original needs restoration.
1999 Trans Am LS1
Old 07-05-2011, 08:11 PM
Has Lenco and B&J pattern
Old 10-09-2016, 12:18 PM
hill67bird hill67bird is offline
is the bellhousing still available?
